My computer won't turn on. Everything's dead.
  • Computers & ... Master
  • 5,660 Answers
1) Check to make sure your surge protector has power. Power On LED light is lit.
2) Check THE receptacle, in the surge protector that the computer is plugged into.
I have had a few bad surge protectors where just THAT receptacle was bad.
"Hmmm, surge protector Power On LED light is lit.
Monitor, printer, and router plugged into the surge protector have power."
Plugged a table lamp into THAT receptacle in the surge protector, that the computer was plugged into, found it to be bad.
3) Perform the test to check whether it is a bad Power On switch, or a bad Power Supply.
The Power On switch is located inside the plastic Power On button.
This is a generic Power On switch (ATX), that I have found fits many computers,
http://www.directron.com/atxswitch.html
The test involves bypassing the Power On switch. Has nothing to do with the Power On switch wires.
A jumper wire is used on your 20, or 24-pin ATX main power cable's connector.
The jumper wire goes from the Soft Power On wire, (Also referred to as PS_ON. It is a Green wire), to ANY Black wire in the main power cable's connector.
Since you didn't post what computer you have, (Computer manufacturer, and Model Number), I have to give you generic information.
It may also be, that there is no direct information available for the computer you have.
1) This is a 20-pin ATX main power cable, and it's connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
2 This is a 24-pin ATX main power cable, and it's connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[Older computers use the 20-pin ATX main power cable. Later computers needed more power to the motherboard, hence 4 more power wires were added. 24-pin ATX main power cable ]
Computer unplugged from power, observe Anti-Static Precautions.
[ Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
Computer on a table, computer unplugged from power, computer case open; TOUCH the metal frame of the open computer case.
This will relieve your body of Static.
While working on your computer your hands, and forearms should occasionally touch the metal frame.
But if you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return ]
If you bypass the Power On switch, and the computer comes on, (Power Supply comes on), you have a bad Power On switch.
If you bypass the Power On switch, and the computer Does Not come on, (Power Supply), you have a bad Power Supply.
The test is to use a jumper wire on the 20, or 24-pin ATX main power cable's connector.
The jumper wire connects from the Soft Power On wire, (Green), to ANY Ground wire. (ALL Black wires are Ground wires)
The 20, or 24-pin ATX main power cable is plugged into the motherboard.
The Power Supply, (Computer), is plugged into power.
Use one end of a jumper wire, to go down into the socket hole with a Green wire, and the other end of the jumper wire to go down into a socket hole, with ANY Black wire.
The jumper wire must go down into the socket hole pretty far.
The jumper wire goes down into the socket hole, right next to the wire that is already in the socket hole.
The jumper wire has to go down in the socket hole far enough, to touch a metal terminal that is on the end of the wire.
I realize that this may look complicated on 'paper', but I'm just being very detailed.
Most use a jumper wire made from a paper clip. The paper clip's diameter is thin enough to slide down into the socket hole, right next to the wire that is already in the socket hole. (And touch the metal terminal at the bottom of the wire)
The paper clip is straightened out, then bent into a U-shape.
Black plastic electrical tape is wound around the middle of the U-shape.
The taped part is what you hold onto.
The voltage for the Soft Power On wire, (Green) is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
Just in case you have reservations.
There may be a spark. Warning you in advance.
You may wish to use a glove, on the hand that holds the jumper wire.
Just make a brief contact with the jumper wire. No more than 2 seconds should suffice.
If the Power Supply comes on, you have a bad Power On switch.
If the Power Supply does not come on, you have a bad Power Supply.
No if's, and's, or but's about it.
Tell me the computer manufacturer name, and model number, and we'll see if a compatible Power Supply can be found.
Post in a Comment.
Posted on Oct 06, 2010
2008 Jeep Liberty
Possible solution - This happened to me and my battery was dead in my key fob and also I needed an ignition switch because a piece on it was broken which therefore wouldn't turn to start the engine.
Apr 26, 2013 | 2008 Jeep Liberty
My 1997 Subaru Impreza won't turn over.
here is a trick ...jump it off and unhook + batt cable if car shuts off alternator if stays on replace batt
Aug 16, 2012 | 2002 Subaru Legacy
My 2007 tundra went dead. The ignition won't start
There are several possibilities ranging from a defective starter, to bad cable connections, to the onboard security system locking out the starter relay, or an aftermarket accessory interfering with the starter circuit, or a locked-up/damaged engine.
I have had vehicles towed into my shop for similar complaints when the only problem was that the customer was using a cheap duplicate key that they had made at the hardware store that did not have the required computer chip in it.
I have also had vehicles towed in where the customer had replaced the battery and did not have good cable connections or forgot to connect one of the wires that was supposed to to get hooked-up to the battery connector.
Then there are the questions: Are you getting any kind of "clicking" noises when turning the key or is it completely dead? If it is clicking, WHAT is clicking? Is it the starter motor itself that you hear or just the starter motor relay? Do you have battery power at the starter "S" terminal when turning the key? If not, is the transmission selector in "PARK"? Does the shift indicator on the dash indicate that the transmission range sensor is in "PARK"? (possible defective transmission range sensor) Are there any fault codes stored in ANY of the modules connected to your onboard computer network?
It is really hard to say without being able to see the truck.
Mar 18, 2012 | 2007 Toyota Tundra
My scanner used to work just fine, but suddenly it won't work anymore. It is plugged in and everything, but suddenly in Photoshop, the Xerox 7600 option under File > Import disappeared, and the WIA...
Have you tried an other USB cable??? have you tried a different USB port on the computer??? try the scanner on an other computer as well, does it have POWER???... eazy stepps to troubleshoot all types of devices is to first make sure the device has POWER, than concentrate on connectivity (cables, ports, etc...) than try it on an other computer, re-install drivers as well..., check for viruses also, when everything is clean and it still not working than replace the device... it's dead (send flowers) ha! just kidding!
Jul 23, 2011 | Xerox 7600 Flatbed Scanner
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
The car runs but everything like the radio, ac power windows turns off and will not work. this stared yestuurday and has been driven 2 more times and now the battery is dead. i used my code reader and do...
If the battery is dead, that should be your first clue. You need to diagnose your charging system. If the battery is dead, it is also EXPECTED that you won't get any codes. If the charging system voltage goes below 9 volts, all kinds of weird things will happen. Computers don't like it much when you put them on a crash diet. :)
The first thing I would suspect is a bad alternator.
May 11, 2011 | 2006 Ford Freestar
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Locating Body Control Module
turn signals blinkin fast sound like you have a blown bulb in them your body control computer should be located under the vehicle near the rear axle
Sep 20, 2008 | 2001 Pontiac Grand Am SE
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
