Question about Maytag Neptune MDE5500AY Electric Dryer
Not getting any heat on any setting. My Neptune dryer is now 6 years old. Is it possible a fuse has blown? Thank you.
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
No heat
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have Maytag Neptune dryer. It is not heating when drying the clothes. It is about 10 years old
the most common problem if its electric is the heating element the secound most common problem is the fusable link if the fuse link to the relay has not blown then replace the heating coil
Sep 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My tumble dryers not drying my clothes, i've had it coming up 6 years
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 22, 2010 | Whirlpool LER5636P Electric Dryer
Dryer run not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 14, 2008 | KitchenAid KHGV01RSS Dryer
Dryer has no heat on any setting after house fuse blew.
We got the problem with our dryer figured out. After checking possible solutions on-line, we checked the power going into the dryer with a ohm tester and discovered we weren't getting full power that we expected. Just after changing the fuses in the house the first time we heard a snap sound but the fuses appeared to be fine, but no heat to the dryer. When we discovered we weren't getting full power we used the ohm tester to test the fuses indiviually and discovered one of the fuses were bad. Put in a new fuse and wala! the dryer is putting out heat. Thank you so much for the service you provide to "do-it-yourselfers" like us!
Nov 10, 2008 | Dryers
Dryer runs, tumbles clothes, but does not heat
Heating element
Thermal fuse
Wiring
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Maytag Neptune Gas Dryer
You have a Hi-Limit t'stat located at 12 o'clock on the flame shroud. A safety fuse is also located on the flame shroud at 1 o'clock. The flame sensor is located at 9 o'clock on the flame shroud. The Hi-Limit can be temporarily bypasses for a quick check, as well as the fuse, but do 1 at a time. Be sure to unplug the dryer before testing.
If that doesn't help, let me know if you need more assistance.
Dave E. (Illeagle)
May 30, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune breakdown
Warning! Shock Hazard! Disconnect dryer from power source before servicing.
I assume you repaired a wire that attaches to a white ceramic insulator terminal? If you have a volt-ohm meter, you can check continuity of the element and hi-limit thermostat and overtemp.fuse located on the element shroud. If you ddon't have access to a meter then visually inspect the element for a break in the coil. The fuse and hi-limit can be temporarily bypassed 1 at a time to eliminate 1 or the other being faulty. Also double check your heat temperature settings on the control panel to make sure it did not become de-selected. There are also temperature control thermostats attached to the blower housing in lower left corner of the dryer that can be temporarily bypassed to test for failure. Tip: Clean lint filter after each load. Clean vent to outside,(check every 3-6 months), and refrain from overloading dryer. This will help extend the life span of the element and the dryer itself.
Hope this helps!
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The heater and timer do not work
The timer won't advance unless te clothes are drying with heat.(No heat, no movement).
Check your fuse or breaker box to see if you have a tripped 30 amp breaker,(Flip breaker OFF then back ON), or blown 30 amp fuse.(Replace both 30 amp fuses to eliminate the possibility of being wrong).
If these check ok,(be certain), then you have a breakdown on the heat side of the 240 volt circuit, at which point, I would recommend calling a technician.
Let me know if I can be of any more assistance.
Gas dryer won't heat
Heating element
Thermal fuse
Wiring
Dec 09, 2007 | Neptune MLG2000A Front Load Stacked Washer...
Maytag Neptune MDE5500AY Electric Dryer Logo
43 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
