Question about Garden
How do I replace the pull chord on my weed eater fb25 blower? The chord has broke.
5 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
SOURCE: WEED EATER BLOWER BV 1800 FUEL FILER REMOVAL AND REPLACEMENT
According to the Weed Eater Instriction Manual, page 8:
REPLACE FUEL FILTER: To replace fuel filter, drain unit by
running in dry of fuel, then remove the fuel cap/retainer assembly
from the tank. Pull filter from tank and remove it from the the
fuel line. Install a new fuel filter on fuel line; reinstall parts.
Tip: Sears outlets have a big selection of tune-up items for
blowers, etc. Try them for needed parts.
Posted on Apr 02, 2009
  • 203 Answers
SOURCE: Weed eater Feather Lite Blower - replacing pull
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Posted on Nov 21, 2009
SOURCE: replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
Posted on Jun 28, 2010
Gas to oil mixture for 1 gallon of gas
most of my 2 cycle machines are 50-1 which amounts to 3 ounces of oil per gallon of gas. If 32-1 than it would be 4 ounces of oil per gallon of gas. Hope this helps.
Nov 26, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
Mar 14, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Can a gas powered blower be repaired if it was drooped in pool.
it's hard to get it running again...probably it's not worth a try...
- you should open the carburetor, dry and clean it.
then the spark plug has to be removed and dried with a blow torch, also inside the cylinder opening.
then you better buy a can of starter spray to ease a start procedure.
Weed Eater FB25 Handheld Blower Parts 25311960-50ikml0pgld1svv5r0lj5py2-4-0.jpg 25311960-50ikml0pgld1svv5r0lj5py2-4-2.jpg
Dec 07, 2014 | Weedeater 25cc 2-Cycle Gas Blower - FB25
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Oct 05, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Hey how are you My weed eater fb25 blower pull cord is stuck half way and dk how to get to it
take it off the blower and clean the dust out it ,then spray WD 40 on the pulley to free it up .
Aug 10, 2014 | Garden
I have the featherlite weed wacker the prime button won't come up when i push it down' won't start
For the bulb to come back up it needs to easily pull fuel from the carb, if the filter in the tank is blocked, or there is dirt in the carb the bulb will not come back up, replace the filter in the tank, if no better you need to clean the internall filter in the carb.
Aug 10, 2013 | Poulan Fb25 Weed Eater 25cc 2-cycle...
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
