Question about Panasonic AJ-SD93 DV / Mini DV VCR
When I press the power button on the Panasonic AJ-SD93 DVCPRO50 deck, the fan in the back starts spinning but, the lights in the front don't turn on and I can't insert a tape into the deck.
  • videoeditors Oct 06, 2010
    Yes it was helpful.
    President:
  • 2,777 Answers
That means the main board or the actual power supply of this unit has failed. It is a major repair and for a high end device like this one you are going to want Panasonic themselves to do the repair. Give them a call at 800-211-7262
Thanks
Tim
Posted on Oct 06, 2010
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
How much?
i think this not so expensive lol...........:-) here it is..$6,995.00 according to this site.. http://www2.shopping.com/xPO-Panasonic-AJ-SD93
Apr 30, 2010 | Panasonic AJ-SD93 DV / Mini DV VCR
Err-32 on my aj-d230h
IF IT IS A PANASONIC PRESS STOP BUTTON AND CHANNEL UP TOGETHER TAPE SHOULD EJECT.TRY THIS WITH POWER ON STAND BY.
Apr 19, 2010 | Televison & Video
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
I am trying to use a Panasonic AJ-D650, which hasn't been used for about 5 years. Initially the DVCpro tapes wouldn't load but they are now loading correctly. However if I press play or any other command...
most likely problem with the AJ-D650 is deteriorated electrolytic capacitors on the mechanism drive board. when these caps fail, the mechanism will not load completely, if at all. also check for bad capacitors in the signal path from the head drum. first and easiest step is to clean the heads; often a good cleaning will restore operation to a non-playing machine.
Oct 22, 2009 | Panasonic Televison & Video
Flashing stop light on a panasonic AJ-D450
The "stop" button will flash if there is no reference video signal connected to the deck.
Oct 05, 2009 | Panasonic Televison & Video
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Firewire Card Needed
ebayd AJ-D230H got four sellers of the deck, maybe ask the sellers what else they have for accessories
Jul 25, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic AJ-SD93 DV / Mini DV VCR Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
