Question about Gestetner Office Equipment & Supplies
I have a Gestetner 1802 and today it says functional problem SC320. Can you explain what that is?
    President:
  • 2,072 Answers
Most likely what is called the polygon motor in the laser is bad. It is the motor in the laser unit that has mirrors mounted to it . It is the scaning part of the laser.
Posted on Oct 06, 2010
Error sc320 how to reset this problem please explain in detail. thanks.
SC320 IS A LASER PROBLEM .
KINDLY AND CEREFULLY REMOVE THE LASER UNIT AND WASH WITH DETERGENT VERY THOUROUGHLY AND DRY UNDER THE SUN FOR ABOUT THREE HOURS AND REPLACE IT BACK TO ITS POSITION .
IF U POWER THE MACHINE AND THE SAME PROBLEM OCCURS, CHANGE THE LASER COPLETELY.
GOODLUCK.
Oct 08, 2013 | Ricoh Aficio 1018 Printer
Sc320 functional problem
YOUR PROBLEM IS IN THE LASER ASSY. FIRST GUESS IS THE POLYGON MIRROR MOTOR.IS SLOWING DOWN AND NEEDS REPLACING.USUALLYYOU CAN HEAR A WHINING NOISE AS
THE MOTOR REVS UP APPROX.30000RPMS. SC320 DOES NOT MEAN THE SAME THING FOR EACH MODEL BUT IT DOES MEAN A PROBLEM IN THE LASER UNIT
Apr 29, 2010 | Gestetner Office Equipment & Supplies
Error SC320
your polygon mirror motor has stopped turning. alot of reasons why. 1 bad mirrior motor. 2 need to oil motor. you have to use thin weight oil 5w. 3 power supply. 4 laser. 5 sync pcb. 6 motor fialed becasue of cooling fan
Jan 02, 2010 | Gestetner 2712 Digital Imaging System...
I came into work today and the copier said funcional problem call for service. this machine has been working fine how can I clear that off of it? It also is showing a sign SC320 and a phone number to call....
You did not state the Make/Model but this is a Ricoh/Savin/Lanier/Gestetner failure code so I will go with that.
SC320 is a laser mirror motor failure, also referred to as the laser scanner. Most likely this code will not reset, but I would at least try powering the machine off then on to check. If not, I am sorry to say this will require a trained service technician to replace. Parts and Labor approximate cost should be around $360 depending on model.
Good Luck and sorry again to be the bearer of bad news.
Oct 23, 2009 | Office Equipment & Supplies
We have a gestetner DSm622sp we are getting an error code SC320.
Hello sir; the error code you have display, that's means laser motor don't work, replace it!
May 18, 2009 | Gestetner DSm515pfd Digital Copier -...
Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Apr 30, 2009 | Office Equipment & Supplies
Error SC320
The laser motor is cooked
Apr 12, 2009 | Office Equipment & Supplies
Ricoh 1022 - Error SC320
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
Mar 02, 2008 | Gestetner DSc332 Copier
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Oct 24, 2007 | Gestetner DSm618 All-In-One Printer
275 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
