I have mold problems when using ventless propane gas wall heaters in a small rental house. The house is very tightly insulated. How can I solve this problem?
  • 59 Answers
Air requirments for these units are 50 cubic feet of air for every one thousand BTU'S - if you are under this amount need to have fresh air into the room with a grill that has 1 square inch for every thousand BT'S.
Posted on Oct 12, 2010
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Jan 01, 2017 | Vanguard Heating & Cooling
Pilot light blows out while heater gets hot. Mr Heater 30000 butu ventless propane wall heater.
call a gas fitter for the repair
could be a freezing of the gas because of a blockage that is restricting gas flow
gas is not a diy repair
Dec 31, 2016 | Blue Flame Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
Black soot is on the walls & ceiling around the baseboard heaters in the rental house that I live in. What is causing this & how do I clean this off?
If these are electric base board heaters, that is probably not soot, but instead mold. Put a little bleach in a spray bottle and try spraying it right on to the black soot looking stuff and see if it will disappear. If it does, it is mold. Bleach will kill the mold.
If these are gas heaters you need to call a service man NOW. Black soot is a sign of gas burning raw and can be very dangerous. Turn them off if this is the case.
May 18, 2011 | Heating & Cooling
I have a Kozyworld wall mounted ventless propane heater. Whenever it automatically turns ON or OFF you get a strong odor of propane. While it is ON you don't smell propane. What is wrong with it. I...
You need to clean it out. Take the wall heater down and use a air compressor to clean out the gas system. Also clean the orifice out. Make sure that the chamber is clean and clear of spider webs and dust.
Jan 26, 2011 | The Companion Group Kozy World Portable...
What causes black soot to smoke up our complete house with ventless logs
Take the pilot and burnner assembly all apart and blow it out with compressed air then reassemble and make sure that the air shutter is totally open. The soot is cause by a bad air/fuel misture that is too rich and cause carbon to form from incomplete combustion. If the burner continues to make soot then reduce the gas pressure to the gas log at the pressure regulator.
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 24, 2010 | Empire DV-215 Direct Vent Natural Gas...
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
