Question about Gaggia Titanium Espresso Machine
If pump does not work then what should i priory
    Scholar:
  • 29 Answers
Need more information to solve your problem.
Does the pump come on (do you hear it?) but no water comes out when you make coffee?
When you select Hot Water and open the steam valve, does the pump run and does water come out the steam valve?
If you hear the pump running but no water is coming out - then it could either be that the pump needs to be primed. In that case you would select Hot Water and open the steam valve all the way and let water run out the wand for a minute or two.
If the steam wand delivers water but you don't get any water when you brew coffee, then either the coffee is ground so fine that the water cannot go through the coffee grinds OR the filter disc may be plugged up. Try grinding coarser and try removing the filter disc and cleaning it with a toothbrush - hold the disc to the light and verify that you can see through all the tiny holes.
If it pumps water for coffee but you don't get water out the steam pipe, then the steam wand may be plugged with hardened milk - in that case remove the plastic frother and soak it and clean it. Also use a bent paperclip to clean the hole in the end of the chrome steam pipe.
If the pump doesn't run at all and you don't hear any pump noises ever - then either the pump has failed or has a loose wire.
Posted on Nov 03, 2010
Lost Maxi cosi recyning rod
Hi
Which model Maxi-Cosi Priori is it?
The original Priori was discontinued some time ago and we can no longer support this product for spare parts or repairs. We would advise that this particular seat is replaced.
The Priori SPS, PrioriXP and PrioriFix carseats are still part of the current range so can be supported for spare parts and repairs. If you visit www.maxi-cosi.com and select which country you're in you'll find a Contact Us tab on the right side of the page where you can click to send your enquiry to the customer care team in your country.
Replacement Recommendation for Older Carseats Carseat Bases
Apr 01, 2014 | Maxi-Cosi Priori
How to refit seat cover after washingt
Hi
Which model Priori do you have?
Original Priori was discontinued some time ago - Currently available PrioriFix, PrioriXP and PrioriSPS
Feb 24, 2014 | Maxi-Cosi Priori
I need an inner replacement side protector system, where can i get them from?
Hello Kirsty - The original Maxi Cosi Priori carseat was discontinued in the UK some time ago and replacement polystyrene inserts for this product are no longer available. If it is a Maxi Cosi Priori SPS, XP or Fix model, you can purchase replacement polystyrenes via your local Maxi Cosi retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Aug 10, 2011 | Maxi-Cosi Priori
I have a maxi-cosi priori, and i need to adhust the top strap? and i lost the instruction manual??? please help
The maxi-cosi priori manual can be found here: http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/4358-4274%20US%20Priori.pdf
Aug 09, 2011 | Maxi-Cosi Priori
How so i install my car seat rear facing
Good Evening
In the UK the Maxi Cosi (original) Priori, the Priori SPS, Priori XP and PrioriFix carseats are not for rear facing use. They are only to be fitted forward facing.
May 23, 2011 | Maxi-Cosi Priori
I need fitting instructions for straps for Maxi
You can download the manual on the bottom of this page, just below the award signs:
http://www.babycare.nl/maxi-cosi-priori-sps-bjrn-p-107.html
Hope this helps,
Babycare.nl
Erwin de Raad
Jun 13, 2009 | Maxi-Cosi Priori
Maxi cosi Priori, Adjustment of straps to the upper of the three
There is a door in the back of the seat (only accessible when the seat is fully reclined).  You have to open this door.  You can then pull the splitter plate out from behind the seat.  It is easiest to do this if you loosen the straps all of the way.  Remove the straps from the splitter plate, and rethread them through the desired slots and re-attach to splitter plate.  Close the door and you are done.
Jan 29, 2009 | Maxi-Cosi Priori
I need full instruction manual for the maxi-Cosi Priori XP please !
Go to the maxi cosi website, for the XP model you need to go to the UK-Britain website...you can download the manual there.
Nov 04, 2008 | Maxi-Cosi Priori
Maxi cosi priori
contact manufacture at
email Consumer Relations at consumer@maxicosi-us.com, or call Consumer Relations at (800) 951-4113.
they should be able to help
May 26, 2008 | Maxi-Cosi Priori
Maxi-cosi priori previous model
There is a brackety thingy (sorry I'm not real technical) in the back that the straps connect to. Remove them, extend it, and re-connect them.
Jan 20, 2008 | Maxi-Cosi Priori
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
937 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
