Question about Garden
I own a GBG 2000 pressure washer and I cannot get it to run. It just hums and then after 3 seconds, kicks off the reset button. What do I need to do?
    Problem Solver:
  • 12 Answers
Don't know this model intimately but it looks similar to the Karcher which is really total **** nowadays as its all made of plastic. The motor has a weird switch mechanism but if it tries to run and the motor doesn't then 100:1 the motor is seized. Very unlikely it's the actual motor but the pump is a "swash" plate that opens 3 stainless steel thin flat valves. the bearing that the pump shaft goes through is a phospher-bronze plain bush with a seal each side and if this has dried out then you are screwed. Same if you model has steel roller bearings. However, if it does run and build up pressure and it stops because the output pressure is too high then the overload pressure switch is faulty. If it is the Karcher type then again you are stuffed but if it is similar to the Nilfisk then a replacement is available for around £100 GB Pounds - probably cheaper to buy a new one.
Posted on Nov 05, 2015
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Power washer motor will not kick in. I've got a
Hi and welcome to FixYa I am Kelly. When an electric pressure washer sits for an extended time the residual water inside the pump eventually starts the corrosion process. In as little as 2 or three months enough corrosion can form inside the pump to freeze the pistons in the pump and of course the motor in place. Here is what you can attempt to try and free the pistons. Place the unit on a piece of cardboard and then slowly introduce a light weight oil into the water supply connection. You will need to ensure you add enough oil that you start to notice it at the pressure hose connection. Let this sit overnight on the cardboard.
Next day you need to attempt several rapid off and on sequences (10 at a time less than 1 second each) using the torque of the motor to momentarily make micro movements of the pistons. Let the unit sit for 30 mins if it did not clear and try it again (10 more times rapid on/off cycles) Let it sit another 30 minutes and make the final attempt to get the pump free.
It most likely will free up by doing this but if the interal corrosion / debris is too much your faced with having to physically remove the corrosion by opening the unit and doing repair.
Kelly
Posted on Aug 26, 2010
Pressure washer won't run
motor is seized or rusted
Jun 29, 2015 | Electric Garden
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What to do when washer is locked on control locked?
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Says control locked
OR
OR
OR
Unplug washer
Feb 14, 2011 | Washing Machines
How do you unlock control lock on front load washer?
Press the end of cycle signal- button for 3 seconds
OR
OR
Unplug washer
Jan 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I own a GBG power 2000 pressure washer and I cannot get it to run. It will hum for 3 seconds and then trip the reset.
Release the trigger pressure to allow for start up. Sounds like motor jambed by pressure build up. After motor is running it should be okay.
Oct 06, 2010 | Garden
Will not start, do not smell any gas
i had a 2000 chevy venture wbe. i had to replace the in-tank electric fuel pump at 107,000 miles. open the fuel door, remove the gas cap and have someone listen closoly. try to start and if you hear a HUMMING sound once the key is turned, then fuel pump is working. if no hum, the fuel pump is bad. upon start-up it kicks in 2-3 seconds to build up fuel pressure...
Sep 20, 2009 | 2000 Chevrolet Venture
LOW TIRE PRESSURE WARNING LIGHT
Turn ignition to run position,go to fuse panel right hand of vehicle,push and hold reset button for 5 seconds,low pressure light will flash 3 times,start car it should turn off the low pressure light.
Jan 05, 2009 | 2000 Buick Century
Garden Logo
879 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
