Question about Lexmark T622n Laser Printer
HOW DO I CHANGE DUPLEX SETTING FROM = OFF* INSTEAD TO = ON *
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
A T622n has no duplex function.
Posted on Oct 07, 2010
How do I get the scanner to scan several pages into one document instead of each page being an individual document
Dear
Pl. do select the multiple page in scanner software (application) setting, and format setting to pdf type.
Thanks.
Feb 26, 2015 | Canon MF-4150 imageClass Black & White...
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
Setting the duplex printing for RICOH Aficio MP 3351
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Feb 24, 2011 | Ricoh Aficio MP 161 Black and White Copier
HP LaserJet 4250 PCL 6 - Cannot get Duplex disabled
Try turning Duplex off at the printer. See if that does what you want.
Jun 23, 2010 | HP LaserJet 4250dtn Printer
I can't connect with 100 duplex setting. it works
You have to change the quality of service on your router.
Dec 09, 2009 | Westell Wirespeed VersaLink...
Print one side only
Plz Check Duplexer Is Disable either thru Hardware or Software
Sep 14, 2009 | Office Equipment & Supplies
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Hi, i have an older set of uniden radios that i no longer have the manual for. one of them is stuck on a setting where i can transmit, but can't receive. anybody know how to change this? i'm not sure how...
if i've ever had this prob its because one radio is on "duplex" mode and other is on "simplex", if you know what i'm talking about this info is prob useless, but on most hand held radios there's a button that says d/s, dup/sim or just dup or sim, press or hold to change from simplex to duplex , probably see it on display, but anyway have em both set on same setting either simplex or duplex
Aug 12, 2009 | Uniden 7 Mile two-way Radio
When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Lexmark T622n Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
