Question about Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven
Upper oven onlyworks on broil. When I turn the bake setting on, the broiler comes on and not the bake eliment.
Could be a bad element or a wire burned out,going to the element in the back of the oven. you will have to pull out the unit to check the wire. turn off the power to the oven before you start. element can be checked from the inside.
Posted on Oct 06, 2010
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
Whirlpool built in electric oven
The upper element is for broiling and should not come on until you tell it broil. If it is coming on as soon as you turn on the breaker then it sounds like the printed circuit control board is bad. There is a relay on the board that engages when you program in the broiler. The relay can be hard to find and may not be removable. My broiler would come on when I programmed in the bake mode, go into runaway heat, put up a F10 code, and shut off. I could not clear it until I programmed in the clean mode for 2 hours. Now it works great.
Sep 07, 2014 | Whirlpool RBS275PD Electric Single Oven
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
The baking element in the oven does not appear to be working
HI.I would test to confirm the actual issue. This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
Use This procedure below to confirm the failure.
With a multimeter, use these steps below to physically test for element functions.
2.Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
4.Pull the element part way out to expose the oven's wiring connected the element.
5.Label the wires and secure them in place so they do not fall back into the cavity.
6.Disconnect the wires from the element.
7.Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
8.If the element tests okay, reconnect the wires, slip them back into the cavity and re-secure the element.
Oct 05, 2009 | Smeg Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
Mar 13, 2008 | Amana AOES3030 Electric Single Oven
Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
113 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
