Question about Philips Philishave HQ7782 Electric Shaver
The problem with my shaver is that the red light flashes whilst shaving plus when i turn it off the green tap light comes on
  • 577 Answers
Would you please go thru the user manual "Troubleshoot" portion to find out the official solution.
Just in case,if you cant locate the printed manual please visit the web site provided below to download it in Pdf format...
Take care ..Regards
here is the link to the USER manual for the HQ7782 in English.
http://www.p4c.philips.com/files/h/hq7782_33/hq7782_33_dfu_eng.pdf
Posted on Oct 06, 2010
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
Flashing head message
This signal reminds you to replace the shaving heads of your shaver. New shaving heads guarantee continued optimal shaving performance.
What reminder signal your shaver gives depends on the model. Some shavers beep, while others show a flashing shaving head symbol on the display. Some with red half circle arrows, around the 3 shaving heads, or a flash of the 3 shaving heads. There are also models that beep and show a reminder signal on the display at the same time.
How to reset the reminder signal:
The replacement reminder is repeated at 7 to 10 successive shaves, depending on the model.
In some models, you can reset the razor. Press and hold the On/Off button for approximately 10 seconds.
If the shaving head symbol is shown in combination with an exclamation mark ("!") and a faucet symbol, it means that the shaving heads are blocked. When this happens, you have to clean the shaving heads or replace them. (Note: Only certain models have this feature)
Hope this helps, as mine is doing the same thing now.
Jun 22, 2013 | Philips Norelco 1250x Sensotouch 3d...
A red warning light is flashing...looks like the razor heads icon...what does this mean??
It's means that you should change new replacement heads, that Norelco RQ10 shaving heads for Norelco Arcitec Electric Shaver heads replacement parts.
Jul 06, 2011 | Norelco Arcitec Electric Shaver -...
What does a flashing red light at bottom of display when you turn razor off mean looks lit the 3 rotary blades
It means they want you to buy a new shaver head. U dont need too, and the light will automatically go off after 7 shaves from when it first came on.
Mar 06, 2011 | Norelco Arcitec Electric Shaver -...
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Red warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Apr 06, 2009 | Philips Philishave HQ7782 Electric Shaver
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Philips Philishave HQ7782 Electric Shaver Logo
275 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
