Question about HP Compaq Presario V2000 Notebook
Sound card When using headphone jack output through external speakers, recently, the Quality of sound varies out of one side of speaker during playback of prerecorded music and DVD. Also sometimes there is a hum as well. To troubleshoot, I have changed the cables and tried different CD's and DVD's. Was wondering if the sound card may be lose or wearing out. It is Conexant AMC Audio. Thanks
  • 65 Answers
YES, but you cannot change this yourself it actually needs to be sent to service, if your still in your 1 yr warranty or have a service plan through best buy, i would bring it into them... the reason why you cannot do this is because it is sautered on the motherboard just like the graphic card...
Posted on May 28, 2008
No sound out of labtec lcs 1020 speakers how to plug in
On a desktop you plug them into a jack located on your sound card (varies by card model) . Laptops use the headphone jack to connect external speakers.
Feb 17, 2015 | Labtec Lcs 1020 Computer Speakers In Box
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Hooking up speakers.
Speakers do not normally connect to a microphone jack.
But if it has a headphone jack usually has a symbol like one of these.
http://symboldisco.wordpress.com/2009/02/
Then you could use that as the output to your speakers.
also if it has phono outputs on the back similar to these
http://www.smcelectronics.com/AUDCONN42.JPG
and they are marked nearby as OUTPUT you can also use those
Quality of sound will vary depending on the speaker quality itself.
if you have surround and any of the outputs as shown then with a little care it is still possible to hook up to that.
Don't try to connect INPUT sockets to speaker it will just not work.
You didn't give a specific model so I have only been able to give a generic answer.
Aug 18, 2009 | Emerson Televison & Video
No sound out of the speaker of my lap to dv9000
hi im josh may i he lp you? try this; Sound cards range from simple built-in features to elaborate two-piece devices with physical control panels that mount into a 5 1/4-inch drive bay. The basic purpose of sound cards is to allow the user to hear sounds played by the OS and programs, along with music from audio CDs and other audio files, plus sound from DVD and other types of videos. In addition, these allow for voice communication using software such as Yahoo Messenger, AOL Instant Messenger, and Windows Messenger, along with Internet telephone calls, voice-recognition software, and other uses.
Sound Card Removal and Installation Sound cards are physically installed and removed in the same way as any other card using the same interface (PCI or ISA), except that there are likely to be analog audio cables connected to it inside the computer. On a motherboard with onboard sound, there will also be audio connectors. These connectors are for connecting analog audio to optical drives, modems, and other devices. Some of these connectors are polarized, but even if they aren't, the worst that can happen is that the right and left audio channels could be reversed. Figure 8.4 shows the audio connectors on a sound card.
Figure 8.4: A sound card's audio connectors. External Sound Connections Sound cards can vary as to the number and type of external inputs and outputs. The most basic, usually found on motherboards with built-in sound, have three:
Microphone input: This is for a computer microphone, although battery- powered condenser mics usually work in these jacks.
Line input: This is for an external line source such as a cassette deck or CD player's line outputs.
Speaker/headphone output: This is a headphone-level output that can sometimes drive small, non-amplified speakers. They are usually connected to amplified speakers.
A sound card with a built-in amplifier would have full-power speaker outputs, able to drive most non-amplified speakers. More advanced cards have a whole assortment of inputs and outputs. On many cards, the icons that identify each jack are very difficult to see and interpret, especially when you are struggling just to see any part of the back of the computer. Consult the manufacturer's documentation. Figure 8.5 shows sound card jack panels.
Figure 8.5: A sound card jack panels. Now look carefully at Figure 8.5. The concentric arcs represent sound waves. An arrow pointing toward the center indicates a line input, while an arrow pointing away from the center represents a line output. The microphone and speaker icons are more illustrative than are the others.
Diagnosing and Repairing Sound Problems There are a number of steps you can take to correct sound problems. First, make sure the speakers are powered, turned on, and turned up. Make sure all external connections are correct, and that the cables aren't damaged. Run System File Checker (see Chapter 11). Reinstall the sound drivers. Sometimes, you'll have to remove the device in Device Manager, shut down the computer, remove the card, restart the computer and uninstall any programs that came with the sound card, and then shut down the computer again. Then, follow the manufacturer's directions for installing the card, or just reboot and see if Windows will install it correctly. If you have any trouble with resource conflicts, which would be evidenced by instant lockups, go into the BIOS and make sure Plug and Play is enabled.
Selecting a Sound Card A basic sound card is good for most people. High-end models are good for gamers and musicians. Some people like to have surround sound with their computers, so surround sound models are common.
good luck
Mar 06, 2009 | HP Pavilion dv9000z Notebook
Looking for a schematic diagram
It would be less trouble to disable the internal speakers from the television's setup menu and connect to a set of powered speakers or a receiver using the built-in audio outputs. It will be a challenge to get good sound quality and levels from the headphone jack.
Apr 26, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Connecting Logitech X-540
you have to buy an External 5.1 sound card .. i suggest you buy the creative external sound blaster live .. high quality with lower cost
you can find it here :
http://asia.creative.com/products/product.asp?category=244&subcategory=718&product=10702&nav=1
Dec 28, 2007 | Logitech X-540 Computer Speakers
HP Compaq Presario V2000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
