Question about Magic Chef CER3725AA Electric Kitchen Range
Left front burner does not come on. It worked on previous use. the next use it heated minimally, then quit.
    President:
  • 1,430 Answers
This is usually the burner or the receptacle. Here is a video that will walk you thru testing and replacing a burner and receptacle. They are both inexpensive and easy to replace. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. All parts come with installation instructions.
Posted on Oct 06, 2010
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Left element won't turn off
Replace switch for the element that's won't turn off
Nov 11, 2017 | KitchenAid Architect Series II KECC567RBL...
Gas dryer runs but no heat
Those coils are probably getting hot and quitting then after a long time they cool off and work some more then quit again.62a13a2.jpg2720ab1.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | GE DVLR223 Dryers
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Front left burner wont work.
It sounds like the left front control or element has a high resistance short.
Jan 23, 2009 | Tappan TEF242 Electric Kitchen Range
Left Front and Right Rear burner does not heat up
Both burners should be replaced as well as the recepticles that it plugs into. There are recepticle kits available for this repair.
Jan 11, 2009 | Frigidaire FEF352 Electric Kitchen Range
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Kenmore Series 80 (model 110.74812200); dryer does not always heat up when on. When it does heat up it seems to stop producing heat before the proper temperature is reached
i have the problem.i have replaced the thermal cut off sw. and cycle thermostat next will be the flame sensor.(mntd.on the side of burner duct)remove the plug off the left front and you can watch the burner cycle - havnt figured out how to get to it?
Ben
Aug 13, 2008 | Dryers
Magic Chef CER3725AA Electric Kitchen Range Logo
62 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
