Question about Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum
We ran our Platinum Series 18 volt hand vac until it stopped -- charged the battery overnight but it did not charge. is there a problem with the battery charger or what could cause this?
  • 377 Answers
Most problems with what you have stated have to do with bad contacts between the hand held unit and the battery charger. With the charger unplugged, make sure the contacts on both the charger and hand held unit are clean and not bent. Check to see what the "Light Indicator" should be when charging and reinsert the unit into the charger. If the light does not show what it is supposed to show, move the hand held unit around a bit to see if you can make the connection better.
If this does not do the job, depending on the age of the unit, might be time to replace the battery.
Posted on Oct 06, 2010
How long does it take to charge the cordless vac?
The basic rule of charging is "charge for 3 hours for every hour of use".
You won't hurt anything if you charge it overnight, but don't leave it charging for more then 24 hours.
If you wear the battery out eventually, Batteries Plus can re-pack the battery.
Nov 18, 2016 | Vacuums
It will not hold a charge. Been plugin for days at a time then it will run a minute then stop
Hello Karen, It sounds as though may have a bad battery or the charger is shutting down before the battery gets fully charged.
Nov 01, 2015 | Black & Decker CHV1210 Vacuum
Want to register my shark hand vac. # SV780C14
Hi Louise,here's a link where you can register your Shark hand Vac, https://sharkclean.eu/about-guarantee
Jul 31, 2015 | Shark Cordless 18 volt Hand Vac
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My DD hand vac won't hold the charge for more than one minute and just fades away! It has been charged for 24 hours.
Hi there! Your battery may need to be reset. Try depleting the battery. Run the vacuum until it completely shuts off, then re-charge for a full 24 hours. Hope this helps out! If you still have questions you feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Jun 30, 2014 | Dirt Devil Vacuums
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My dyson dc16 is not holding a charge.. maybe I need to replace battery
Hi its Darran at Dyson.
If you call our Helpline they will be able to run through some simple checks to detemine the cause of this issue.
Please call 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 09, 2010 | Dyson DC16 Root 6 Bagless Handheld...
After charging overnight, Roomba only runs about 25 minutes before shutting down with a red light.At this point the battery measures 15.13 volts ( about 1.26 volts per cell ) My hobby experience is that a...
Reset the Roomba by removing it from the charger, then holding "spot" and "dock" for about twelve seconds. When you let go, the unit will play an ascending series of notes. Then recharge it overnight. If the run time is still short, give Customer Support a call-- be sure to have the Roomba with you when you do.
Jun 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Jan 14, 2008 | Vacuums
Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum Logo
123 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
