Question about Miller Spectrum 375 X Treme Plasma Cutter 907339
I have a spectrum 375 x-treme with the ICE 27t torch. while I was useing the torch ,the power light came on and the torch stoped cutting. we tried several diffrent live circuts including 230 volt.Plugging directly in to the wall socket (no extention cords ).Each time the power light would come on as usual however when I pull the trigger on the torch nothing happens and the power light begins to flash. Could this be a bad power cord ? is there a fuse within ?
2 Suggested Answers
  • 4 Answers
SOURCE: pc board for spectrum 375 s/n lh010317p
contact arndt enterprise 847-234-5736
Posted on Mar 07, 2010
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Dec 29, 2011 | Miller Spectrum 375 X Treme Plasma Cutter...
All lights correct, no start
loosen the retainer cap and twist the consumables and retighten
Apr 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller Spectrum 375 problem
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
Cup light is on machine will not work
The cup light is referring to the outer most part on the torch tip, the purpose of the cup is to create a gap between the tip and the work piece. The light is indicating that the cup is worn and must be replaced.
Nov 09, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller Spectrum 375 X Treme Plasma Cutter 907339 Logo
85 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
