Question about Jenn-Air JCD2389G Side by Side Refrigerator
The water dispenser has stopped working all of a sudden...a little water drips out, but that's it
  • 262 Answers
Make sure water valve was not turned off,
Check water Filter,
Empty Ice container to see if you have problem with ice maker.
if water filer is good & Ice maker are working good
Then there are only two things it could be .... The internal water valve or the line is frozen
Most common is water valve in the refrigerator.
Posted on Oct 06, 2010
Testimonial: "Worked like a charm!"
  • 2miler Nov 24, 2010
    I have the same symptom. But I don't understand from this "solution" specifically what I'm supposed to DO to correct it!
  • 1214 Answers
SOURCE: water dispenser dripping
The seat in the door valve has probably failed or has some trash in it.
Posted on Jan 20, 2009
SOURCE: water dispenser stopped working
Our fridge did this. Unplugged, plugged back in and it reset and is now working.
Posted on Jul 06, 2009
  • 38 Answers
SOURCE: Water dispenser is slow
Change out the filter. If it still happens then you have a blockage in the line. Disconnect the line and flush out.
Posted on Jul 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Posted on Aug 23, 2009
  • 1891 Answers
SOURCE: water dispenser is dripping water when not in use.
replace the water valve its not shuting off completly . things do go bad . this is a dual valve and controls both foutain and ice maker .. mm
Posted on Aug 18, 2010
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
The water keeps dripping from the water dispenser how do I get it to stop
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 23, 2011 | Refrigerators
Water on the floor under the freezer side of unit
It happens to all those old refrigerators. There is a shield separating the drip container and freezer through a small hole. Check if it is blocked. This won't do much of the work and may not be stopped even if you do something. If you can, have a new refrigerator.
Apr 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our Kenmore side by side model number 10653382300 is having a problem with the water/ice dispenser. The water dispenser continues to drip and I can not get it to stop. How can I fix this problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 08, 2010 | Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Use a cup instead of a paper towel. Empty as needed.
Jul 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Auto defrost cycle
you can tell if it is in a defrost by listening in the freezer for a sound similar to water dripping on a hot surface. this should only be for a short time.
Nov 04, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
340 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
