Question about GE GSS25LGM Side by Side Refrigerator
I have GE GSS25LGMB-WW Refrerator the compressor is NOT run and I want to know where the main boar is locate?
    New Friend:
Mine was not working either - and I found the "bullseye" mentioned above. Re-soldered and it works great!! Thanks!
Posted on May 06, 2013
plnolte
  • 62 Answers
SOURCE: GE model bsy25gfmd ww has power,lights and ice
You can try changing your relay/overload, it is on the side of the compressor. If that does'nt work you probable need a new compressor.
Posted on May 12, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Sep 05, 2009
aasc
  • 1606 Answers
SOURCE: compressor stopped running in GE GSS25KGMC WW side by side
Remove the main control board , and look on the soldered side , behind the small black boxes . You will be looking for a " bullseye" which is a pin , where the solder has become unsoldered around it . If you find it , resolder and it should work . If all solder joints , behind the boxes look ok , then replace the board .
Posted on Nov 27, 2009
Testimonial: "aasc was very helpful with his direction and through his help I was able to make the repair! I'm very grateful for him taking his time to reply."
  • 29 Answers
SOURCE: GE GSS25QGMC-WW refrigerator is runnig, but not cool
What is the internal temperature set to? If the fan is running it sounds like you have the temp too warm. It's not going to be cooling on 1-3 (sort of cold not really).
Set temps as far "cold" as possible, wait a about 3-4 hours, check it. If you continue to have issues, you need to have it serviced by a repairman.
Posted on Mar 20, 2010
SOURCE: My GE ESS25XGMD WW side by side fridge is no
First thing to check is the coils in the back of your fridge. If they are icy then you will need to defrost them and this will bring the temperature inside your fridge to a colder level (normal level) If you coils are not icy then the next thing to check is if you have 120 VAC at the connector J7-9 (orange wire) to the terminal J8 (black wire) on the main control board. If you are not getting power on the main board then you will need to replace it to get your fridge working right again. Click on the link below to view a replacement: http://www.partselect.com/PartDetail.aspx?Inventory=2364946&SourceCode=1
Posted on Nov 29, 2010
Where is the power button on ge arctica refridgerator model PSs26mgtb/ww
There isn't a power button that I know of on that model I know that it will stop running if the control board shorts out
GE Refrigerator Main Control Board WR55X10942
Aug 06, 2016 | GE Refrigerators
Model gss25lgmb ww
If the compressor is not making any noise and a fridge is worm it means that the compressor is not working. It could be a faulty compressor or a control unit. If it is a compressor, it is not that simple to replace it yourself, unless you have a proper equipment. Because the unit has to be evacuated and recharged with a refrigerant after replacement.
If it is a control unit, it can be replaced, but I would leave it up to a pro to check it out and fix it, if it is worse.
Jan 29, 2014 | GE Refrigerators
Ge refridgerater model no. tfx28pbda ww the de light is flashing-no defrost current>64 hrs. what is the problem,where is the part located
Normally the auto defrost timer is placed close to the main compressor unit and all you need to look is a the back panel, move the fridge forward and check at the base section where the timer will be found. A quick check for the connection and the working can be confirmed if the stepper motor is not working to move forward. If so you need to replace.
Sep 29, 2011 | Refrigerators
I have a model gss25lgmb bb. Im having issues with (couple of months) my fridge randomly stop cooling. Causing everything to defrost. My fan still seems to be on but not cooling or freezing. PLEASE HELP
If its not cooling or freezing then the compressor has to be checked.The compressor is the part which controls the cooling and freezing in the refrigerator.If the gas / refrigerant in the compressor gets low/ less then compressor will run more but it will not cool due to less refrigerant in compressor.In that case the compressor needs to be replaced. -------------- Also it can be faulty defrost assembly parts causing this issue.The thermostat is got faulty or the heater is not turning off.This also causes every thing to get defrosted.
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.------------
Before that you can try manual defrost reset procedure. The manual defrost reset procedure is as follows : ----First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again.Then go for replacing the parts.-------------------This should help.Thanks.Helpmech.
Apr 06, 2011 | GE GSS25LGM Side by Side Refrigerator
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor stopped running in GE GSS25KGMC WW side by side. Fans run. Is there an inline fuse to check? A circuit breaker anywhere? The unit isn't that old.
Nov 26, 2009 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Ge gss25ifrf ww side by side fridge clicking
Sounds like the main control board is bad . Pt # WR55X10656 . This board is located behind the 8 " X 10 " , panel just above the compressor compartment . The compressor relay , is what you hear clicking , cutting the compressor , on/off . Even the dispensor board , is operated by the main control board .
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model bsy25gfmd ww has power,lights and ice make have power and fan runs, however compressor will not "kick on"
May 12, 2009 | Refrigerators
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
337 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
