Question about Singer 1120 Mechanical Sewing Machine
My machine does not want to stitch together it tangles all up in the bottom its not the bobbin
    Genius:
  • 1,788 Answers
It has to be in your top threading, maybe the thread is tangled, slipped out of a guide, or your needle. If, you cannot find it call Singer at 1-800-4singer and talk to Customer service. Good luck, I hope it is something simple and not costly.
Posted on Oct 06, 2010
Bottom thread is all tangled when I sew. Top looks fine, then flip it over and it's a mess.
is it the top thread that is too loose and making the messy stitch or the bobbin thread. if it is the top thread coming down and making large loops that tangle increase your top tension slowly try a few stitches, repeat till you get back to normal.
If it is the bobbin thread that is tangling, first make sure you are using the same thread top and bottom, some will just not work together, then rethread the bobbin, if it is still too loose there is a little screw on the side of the bobbin casing, the larger of the two, turn it no more than a 1/10 turn to the right if too loose and to the left if too tight. I would make the starting point with a piece of tape or nail polish so you can get back to where you were if this is not the problem. My book says you very rarely ever have to touch the bobbin tension. good luck
Jun 14, 2017 | Sewing Machines
I've had my singer simple 3116 for a number of yrs. For last few weeks I've had problems with the bobbin stitch, it sews fine for a few seconds then jumps & the stitches are a tangled jumbled mess , I've...
You may have a burr from an errant needle strike on your bobbin case or even on the bobbin itself. Check to see if there are any rough spots on or around the bobbin.
If you don't find anything, you may want to remove the bobbin assembly and clean the lint out from the lower assembly. Sometimes the smallest amount of lint or pieces of thread can cause problems with the bobbin.
You didn't mention if the tangled thread happens on the top or the bottom of the fabric. If it is on top, then it is a bobbin issue. If it is on the bottom, then it is an upper tension/thread issue.
Try removing the bobbin, thread, and needle. Rethread the entire machine using a different bobbin and a new needle. This may solve your problem. Good luck!
Jul 07, 2014 | Sewing Machines
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
Bobbin will not stay in bobbin case. No stitches top or bottom. EP 382
have you tried another bobbin? when was the last time the machine was
serviced?
Apr 16, 2012 | Euro-Pro 382 Mechanical Sewing Machine
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
Brother se270d
tighten the tension on the bobbin thread. or you are using the wrong size bobbin spool.
Nov 10, 2008 | Brother Sewing Machines
Bobbin tangles on Brother xr 65
This was happening to me too, I reversed the bobbin feeds and it has not tangled since then. I was orignally feeding the bobbin from the left side and now i feed the thread from the right. It works great this way.
May 19, 2008 | Brother XR-65t Mechanical Sewing Machine
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Singer 1120 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
