Question about Cycling
I have a Roketa MC-07-50t that won't start. The Spark plug is not getting a spark. We have replaced the C.D.I. Still no spark. Help.
  • Anonymous Mar 29, 2014
    I need a diagram foe my bike electric problom
  • 3 Answers
I have a Roketa MC-07-50t - 4bbd330.jpegThis is a asic wiring diagrame for a pitbike and if you carefully follow this with yor new cdi mabey coil and spark plug you should deffo get a good spark and if that fails then you need a new stator plate or inner roator kit off ebay    ... hope this helps    email josh_radford2k10@hotmail.co.uk
Posted on Oct 06, 2010
2008 Roketa MC-75 will not start
Hi, Jerry and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
http://www.extremescooters.biz/manuals/roketa_quick_start_guide.pdf
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsprousa.com/?vehicle_type=Scooter&brand=Roketa&brand_model=MC-75-150&srch=2#searcharea
Roketa MC 08 50 User Manual
Jul 04, 2017 | Roketa 150cc cheap Scooters
I had my 06 gy6 roketa 150cc scooter running good,shut it off n now can't get no fire...wont start...new carb,new plug! Any help?
Hi, Jim and the usual suspects are:
1. Fuel tank empty.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
engine cranks spark but still no start
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
MC04A1501
Roketa bali 150 Owner Manual
Mar 29, 2017 | Roketa 150cc cheap Scooters
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
WHY MY 2008 ROKETA 250CC MC-68A IS NOT GETTING NO SPARK, I HAVE CHANGE STATOR, IGITION SWITCH, CDI BOX, BUT NOTHING. HELP
Hi, Donald and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Roketa 250cc MC54 no Spark SCOOTER PROFESSOR
Honda Ch 250 Your service information center
http://roketapartsdept.com/
http://www.scooterdynasty.com/manuals/MC-54B-250%20User's%20Manual.pdf
Oct 16, 2016 | Roketa 50 Scooters
What spark plug do i buy gor my jonway YY50QT-6 MOPED
Hi, Steve for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Jonway, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Amazon com NGK C7HSA SPARK PLUG GY6 49CC 50CC 150CC CHINESE SCOOTER PIT...
AKA Roketa Scooter MC 07 50 Baja SC50 Strada RX 50 Jalon JL50QT 21 falcon...
http://www.carlsalter.com/pdfs/Jonway%20YY50QT-21.pdf
http://www.carlsalter.com/pdfs/Jonway%20YY50QT-6.pdf
http://www.carlsalter.com/pdfs/Jonway%2050CC%20ENGINE.pdf
Jun 19, 2015 | Jonway Motorcycles
Roketa 125cc wont start! spark plug is not giving off spark?
Check the lead and connections between the coil and the plugs, the battery and the coil. If all else fails check the battery charge.
May 08, 2013 | Motorcycles
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
Roketa scooter won't start
Hi, Ammoncrosset and the usual suspects are:
1. Fuel tank empty.
cranks but wont start
http://www.roketapartsdept.com/catalog/Scooter_Parts-52-1.html
Mar 19, 2017 | Roketa 50cc Gas Moped Scooter
1990 Cadillac Seville won't start. Is it the electronic control module?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 19, 2012 | 1990 Cadillac SeVille
Cycling Logo
446 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
