Question about IBM 6400 Matrix Printer
Printer ibm 6400-p50,at position 60 on printer, not printing at all 1 inch wide.
    Problem Solver:
  • 8 Answers
The fret in that position is bad . Needs to be replaces
Posted on Oct 25, 2010
What driver should I use with a 6400 P50 and Windows 7 professional?
install the printer from control panel ,when the when prompting for select printer there are two tabs there "windows update"and"have disk " select the "windows update" this will take few minutes,then select your printer model
Jul 30, 2014 | IBM 6400 Office Equipment & Supplies
How do I print Microsoft Word documents on an IBM 6400 matrix printer?
What driver are you using for the printer?
Also, when you go to print the document, you will see a printer listed on the top of the print menu screen.
Next to that, there will be a down arrow. Click on the drop down arrow and select the IBM InfoPrint printer you want.
Don
Jan 05, 2010 | IBM 6400 Matrix Printer
The print is only clear on the left side of the forms...
Platen Gap Adjustment (Figure 35)
IMPORTANT Only do this procedure if the original equipment shuttle frame assembly or platen has been replaced by a new or
refurbished unit.
1. Prepare the printer for maintenance (page 338).
2. Remove the shuttle cover assembly (page 357).
3. Loosen the platen open belt (page 415, steps 2, 3, and 4).
4. Raise the forms thickness lever (1) to the fully open position.
5. If you are adjusting any model except the 6400-i20, select a 0.011 inch (0.28mm) flat feeler gauge.
If you are adjusting a 6400-i20, select a 0.012 inch (0.30 mm) flat feeler gauge.
ATTENTION Do not force the platen against the feeler gauge. Damage to the hammer tips will result.
6. Insert the feeler gauge (2) straight down between the hammer bank cover plate (3) and ribbon mask (4), within four
hammer positions of the left end of the hammer bank.
ATTENTION Adjust the platen set screws less than 1/4 turn on one side, then check the other side. Adjustment sensitivity is
approximately 0.03 inch per revolution of the set screw. Also, insert the feeler gauge no more than two inches down
from the top of the ribbon mask.
7. Gently close the forms thickness lever (1). As the platen is closing, gently slide the feeler gauge up and down, keeping it
between the hammer tips and ribbon mask. If the feel is too tight as the platen closes, adjust the 3/32 inch set screw (5)
counterclockwise. If the feel is too loose, adjust the set screw clockwise. With the forms thickness lever closed all the way,
the feeler gauge should contact both the tips and the ribbon mask and move with light friction. Shift the gauge slightly to
verify.
8. Repeat steps 4 through 7 at the right end of the hammer bank.
9. After adjusting both sides, check the gap again at both ends. Readjust if necessary.
Aug 25, 2009 | IBM 6400 Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
Intelligent mail barcode
I'm 75% sure it will, without looking at the postal intelligent mail barcode printing specifications... I will be glad to answer your question, if you can get me the Specs. for the new postal intelligent mail barcode... the other important question is... what is you current IBM 6400-XXX printer configuration? press the print config, then the Start on your printer. 1st Paragraph is all you will need to give me... Worst case, you might need a differenent Emulation program...
Jan 30, 2009 | IBM 6400 Matrix Printer
Controller voltage Problem in IBM 6400 Printer
When you power on the printer, do you hear the fans kick in? If you checked the Maint. Man. skip steps 1 & 2, almost 80% of the time its CMX brd, not knowing your 6400 model? Part# for CMX 40mhz 157450-901, older models have 155802-901 CMX 25mhz V5.5...
Oh yeah if u don't hear fans kick in when you first power up, 80% jumps to 95% chance CMX bad.
I hope you have a current configuration print out! it will save headaches and a lot less down time...
Jan 24, 2009 | IBM 6400 Matrix Printer
IBM 6400-A00 prints normally and stops
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
IBM 6400-A00 PRINTS NORMALLY AND STOPS ERROR
ENTER
ROD
Dec 16, 2008 | IBM 6400 Matrix Printer
IBM 6400-A00 prints normally and stops.
Please Clean or Change the Platen Open Sensor Switch.
Your problems will be Solved.
Regards,
Pawan Dahake
( I.P.S., Nagpur )
INDIA.
Dec 10, 2008 | IBM 6400 Matrix Printer
Wont print on line
You may need to have some driver installed on your PC, that can be downloaded from some IBM printer web site, such as this one:
http://www.infoprintsolutionscompany.com/internet/wwsites.nsf/vwWebPublished/supportdownloads_ww
IBM does not manufacture printers any more, they outsourced that to other places like Lexmark & ProPrinter, so we have to figure out which outsource place is relevant & what name they have for whatever corresponds to 6400 driver.
Sep 27, 2008 | IBM 6400 Matrix Printer
IBM 6400 Matrix Printer Logo
105 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
