Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezer works, upper section not cooling on Kenmore bottom freezer.
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
Bottom freezer refrigerator runs well for about 2-3 months and ten the back ices up and no longer cools the upper refrigerator. The fan does work. This started after about 2 years of purchase. This is...
What is happening is the defrost heater, the heater thermostat or the defrost control is out. Get the service panel off the freezer section and check the heater for continuity and the termination thermostat for continuity. It probably is one of them 2 that is bad.
Service manual
Jun 24, 2011 | Kenmore Refrigerators
The refrigerator section is not cooling. The freezer section work fine. What is the problem?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Feb 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is working fine but the upper area refrigerator is not cooling properly. Temperature is barly cool but not cold.
heatman101
Jan 26, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer is working, but refrigerator section is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
The bottom freezer of my Kenmore Refrigerator works fine but the top refrigerator compartment no longer cools? Thanks
All the cooling happens in the freezer.The refer section relys on a fan to blow cool air into it.When you open the freezer you should hear a fan running.If you hear the fan running, close the freezer door and open the refer door. Look for the vent/area where the air comes in.Put your hand in front of it.If little or no air is coming out it could be a sign of an icing/defrost problem restricting the air to the refer section.
It will take a tech with the right tools to find the exact problem.
If the fan is not running you will have to unplug the unit and remove the back of the freezer section from the inside and make sure ice is not keeping it from turning.If it is free of ice then replace the fan motor.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Dec 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Nov 21, 2008 | Kenmore 73503 Stainless Steel Bottom...
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
166 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
