Question about Sony KP-53XBR45 53" Rear Projection Television
Pic will not come on, was going out, then would come back on. Now just volume works and last year I had the Blue and Green tubes replaced. What can I do now, also the standby light flashes all the time?
  • Sony Master
  • 5,138 Answers
CK small blue capacitor 2K volts it Feeds the Hori output Transistor
I have found them burt.Causing it to kill the high voltage also CK Hori Transistor
Posted on Oct 06, 2010
  • catesro Oct 06, 2010
    Where are these located ?
  • ladywinn
    ladywinn Oct 06, 2010
    LOCATED ON THE LEFT HAND SIDE BOARD THAT HAS FBT flyback Transfomer.
    You can also Type in your search Bar Understanding Sony Blinking Codes.
My philips 55pw9363 has yellow tint I took off the back the blue bulb has no pic in it like the other two but light is bright
It means you have Bad Coolant Fuild in the Blue Tube,most of the time it will be the green and blue tubes and it needs to be changed and New Coolant Fuild put in it. Philips is the worlds worst having bad coolant fuild in tubes.
Mats Electronics has coolant fuild 1-800-628-1118
Jun 22, 2011 | Philips 55PW9363 55" Rear Projection...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony kp51hw40 has green shadows and on edges in pictures and blue flickers on and off, tried all adjustments including screen, focus, and menu??? no luck
The CRTs in this model of TV had a problem with internal leakage. The blue was usually the first to show the symptom (flicker). Because all 3 CRTs are connected to the same high voltage source, when 1 acts up, the other 2 suffer as well. You need to replace the Blue CRT. However, this TV has some age on it... 1 tube will lead to 2 tubes, and 2 tubes to 3... They only last about 7 years. If you love the TV, replace all 3 (about $200 each). I recommend replacing the Red and Blue first, adjusting the geometry and convergence to the original Green. Then replace the Green, adjusting the geometry and convergence to the new Blue and Red.
Mar 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Pic suddenly went dark, very dark. Images seen are oversaturated. hitachi ultrascan hd is about 8 years old. Help!
I have the same problem. I took the back cover off of the TV and blew all of the dust out and the TV started working again. But this only lasted 2 days. Now the TV is dark again.
Jan 19, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Only red tube shows picture, but green & blue are on, just no pic
More likely the problem is the blue and green fluid in the tubes is so cloudy that its distorting the image. Get a fluid kit from www.tvrepairkits.com
Jul 29, 2009 | Philips Magnavox 9P6034C 60" Rear...
A lot of red in pic no matter what we do and tint dose not change anything
As is typical with all Philips projection sets the cooling fluid has become contaminated in the blue and green picture tube assemblies. The red is almost never affected with this as whatever bacterial growth is discoloring the fluid in the blue and green tubes can't seem to survive in red light. The blue and green light is shining up through muddly cooling fluid and that is why the red is predominating. A reputable tv repair shop can pull the tube assemblies and dismantle them and clean and reassemble and refill and do all the necessary adjustments for around $300 to $400.
May 26, 2009 | Philips Televison & Video
Picture turned green
It sound like a bad tube there are three tubes red green and blue.
i suspect the blue tube is bad. tubes cost 160.00 plus labor 450.total . sometimes the tubes
can be fixed or the tv tech can adjust the screen voltage on the tube.
good luck thanks jay leadingedgeelectronics.com
Apr 29, 2008 | Philips 60PP9202 60" Rear Projection...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
No Blue
Nope you did it! Its the blue tube. Go to http://www.samsungparts.com and enter your model number and look up the tube. I did one last month for someone at techlore.com Are you the same person? Oh well look it up but do you have the proper equipment to replace this tube, as its very dangerous to handle!! They have a tendency to implode and then explode if not handled right.
Sep 02, 2006 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
