Question about Norelco SmartTouch 9160XL Electric Shaver
What part can i submerge in water when cleaning the blades?
  • 577 Answers
Even though it has water resist body,like some wristwatches , You are not suppose to submerge it ,to clean just try to keep it under the pouring water in faucet ..
To clean deeply,You can take the Razor Heads assembly out and leave it in cleaning solutions overnight. (please do not disassemble of the blades of its main frame )
My regards.
Posted on Oct 06, 2010
Water pump not working correctly
Probably need a new pump or water tube is clogged. You can try to blow out the pump and water tube with air to clean it internally. You can buy a new pump on line at Contractors Direct for about $50.
Mar 22, 2015 | Felker Saws
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
What's the difference between in-line and submerged water pumps?
There are many differences between the two of them in the way they run but the main difference is the in-line water pumps run outside of water and stay dry the whole process and submerged water pumps run underwater usually in the sump of your filter.
Aug 09, 2012 | Fish
How can I clean my fry baskets?
Wipe down the baskets with dry paper towel to remove excess grease. Then submerge the baskets into a mixture of hot water and vinegar for 10-15 minutes and then rinse off with soapy water and dry.
Jul 15, 2012 | Cecilware V091A 11 1/4" x 4" x 4" Fry...
Vacuum
ok, if u connect the vacuum plate to the skimmer then u need to submerge the hose all the way or the way i do is use the water from the return ( where the clean water returns to your pool and put the hose up against it to where the hose is filled with water and it will sink a little bit, This gets all the air out so it will be easier for the vacuum to get suction. Once u get the water in the hose by either submerging it or using the return water then connect the vacuum plate and then put it on the skimmer...it should start suction right away but if it doesnt that means u didnt fill the hose up all the way or u may need to just giggle the hose a lil to get it to start the suction....I hope this helps, let me know
Thanks and God bless
Jun 23, 2010 | Intex Easy Set Pool 15x36
Kenmore heavy duty 80 series model 110.82682810 Series # C63203374. problem with cold water intake. Very low pressure. Checked everything up to inlet
This is commonly caused by a water inlet valve that has become clogged with sediment, rust or calcified deposits over time. If you live in an area that has hard water, or if you use well water, this can be a common problem.
You can attempt to remove the inlet valve and submerge in a 50/50 solution of distilled vinegar and hot water, or you can simply replace the valve. If you decide to attempt to clean the valve, submerge it for 30 minutes (do not submerge the solenoid contacts) and then rinse with clean water. Sometimes this can clear out the sediment and return them to normal operation. However, if this does not work, you need to replace the valve.
The following link explains how to access and replace:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
A replacement valve (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices differ between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
The part number for a replacement valve for the model you have listed is 285805. The average cost is about $30.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 20, 2010 | Kenmore 24032\24036 Top Load Washer
How to clean the trackball
Remove the plastic ring, remove the trackball and submerge it in water... then DRY it really good...
Jun 03, 2010 | RIM Blackberry Curve 8300
Not spitting forcefully
check supply line both ends at the angel and the pump , flush angel with clean water, clean pump screen replace line , make sure pump intake is always submerged
May 08, 2010 | Hagen Angel spills Water Spitter
What to do with my 2003 Grand Vitara submerged in flood waters
Let the system dry for quite a few days before trying to start, otherwise the computer could get ruined. Most water damages the coil packs and crank shaft position sensor. Hopefully water did not go inside your intake manifold and engine. It may not start. The best thing to do is let it thouroughly dry. Have a diagnostic test done to see if any sensors or circuits got ruined.
Sep 28, 2009 | 2003 Suzuki Grand Vitara
Razor will not turn on.
Take it apart and pull out one of the two batteries for a minute than put it back in. This will reset it fully. Rather than the dumb reset button. Worked for me. Hope it works for you as well.
Apr 20, 2009 | Health & Beauty
Norelco SmartTouch 9160XL Electric Shaver Logo
63 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
