Question about Pioneer TS-W125C/DVC Car Subwoofer
Box spec for 1 off pioneer 12" 1000watt dvs subwoofer
  • 45 Answers
SOURCE: need specs on a ported box for 1 12"stroker 124
I used to be a Cerwin Vega dealer. How much space do you have? Ideally you would want at least 4 cubic feet per sub. If you shoot me an E-mail @ dynami28@charter.net I will be willing to discuss exact plans for your application. I now run a local business designing custom enclosures and electronics for home, marine, and auto. As for your Stroker- A general box design is going to need to be ported with alot of volume (cubic feet) the bigger the better. The actual port diameter and length will be determined after I have some basics from you. I will give you a free design to start with if you Email me the specifics like how much room do you have? how much power? dual 4ohm coils? car, p/u truck, van/suv? The more info the better. If you want something more custom please specify and I will be happy to help.
Posted on Mar 26, 2009
  • 24 Answers
SOURCE: Correct Amount of Power needed for my subwoofer
1000 watt or bigger
you always wanna have a little play room with the amp so it wont blow or short out.
also if you do decide to add another sub....the amp will still be able to push both subs..
yeah so at least 1000 would be perfect but if you dont have the money about a 500watt would still push it hard.
just make sure you have all of the options on the amp tuned to make it sound the best and make sure you have the right enclosure for your car. 500 would do...but 1000 would be best =)
Posted on Nov 16, 2008
etirbynnor
  • 655 Answers
SOURCE: 1 subwoofer stopped working in a box for 2
Hello mccanello55,
You need to remove the subs from the box in order to check the internal box wiring. First, make sure that the wire going from the nonworking sub terminals to the enclosure terminals is OK. Then check the "braided" leads on the back of the terminals going to the speaker cone. If the wiring all looks OK, remove the wires from the sub terminals, and use a multimeter set to the lowest ohm range and check the resistance across the subs terminals. You should read somewhere between 3-4 ohms. If the meter reads infinity (that is no reading at all), then the voice coil is open. If it "pegs" (reads "0"), the coil is shorted.
Either open or shorted means the voice coil is no longer working.
I could not find any replacement parts on Sony's support page, so it's most likely that they don't even repair these. They probably just replace the sub if it's under warranty, and if it's not under warranty, they probably recommend that you buy a new one.
Hope this helps.
Posted on Apr 13, 2009
  • 1126 Answers
SOURCE: what are specs for a ported subwoofer enclosure
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Posted on Nov 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
I have two 15" pioneer tsw383c subwoofer i want to put them in my chevy Silverado year is 2000 i like to no the specs or smallest box available to fit in there
do not waste your time on a small box if you want good sound. also sealed boxes suck and do not produce sound as well as ported enclosures
Mar 12, 2015 | Pioneer Car Audio & Video
How do I make a sub box for my single ten inch re sx 10 inch sub dat is 1000 rms. Da box needs to be tuned to 35 hz
yeah, you likely cant build a box to tune 35hz... try just building a box that has correct spec by the manufacture for ideal operation, and adjust the gain accordingly, that's where you will attain your desired hertz, oh and by the way hertz refers to signal, and pulse rate,
Sep 12, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
What size of box in need Pioneer TS-W307D2 12
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
SUBWOOFER ENCLSURE FOR TWO PIONEER TSW307F 12" FREE AIR
Hi, i know its a long time since 2008.
but do you or enyone else know where to get specs to a pioneer ts-w307f???
im building a box for this sub but i cant find specs so i cant run it on winisd!
i konw this dont answer a qestion but since you did a graph on it in winisd i thought you might have the right specs?
Dec 24, 2008 | Alpine MRV-F307 Car Audio Amplifier
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Feb 20, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Pioneer TS-W125C/DVC Car Subwoofer Logo
214 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
