Question about Sony Handycam HDR-HC5 Camcorder
How doe you turn off the grid display on the sony HC5
  • rick_leetch Oct 06, 2010
    I am a real novice to this camera. I can NOT find the setup options. Please start from the beginning
    Hi Josh sorry but that is not a pict of the sony HDR-HC5.
    can't find the "home"
    My menu on the view finder guide P-menu
    help please
  • 3,083 Answers
I don't have one of these cameras, but here's what they said about the grid feature on cameradigital.com:
Level and Grid Markers With the Level Marker feature, it's easy to keep your camera level for more professional looking video. Line up any horizontal lines in your shot - such as the horizon - to the marker and you can be sure your camcorder is level.
So in the menu, find the Level Marker feature, and turn it off, I think?
All I could find on it, but if you look up the Level Marker feature in your manual, you should find the answer.
Good luck, and hope this helps.
Posted on Oct 07, 2010
  • 567 Answers
The Home Menu gives you a shortcut to all of the different settings and menus that the camera offers. You can select from the shooting, viewing, slide-show, printing, memory and camera settings menus.
To turn off the Grid Display on your Sony HC5,please go to: SETUP options - Shooting Settings 1 Menu: Then choose Grid Lines and select off.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue. I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 06, 2010
  • 1 more comment
  • Anuj Joshi
    Anuj Joshi Oct 06, 2010
    Hi again
    Nice to receive your response.
    Please choose "home" and then browse to "Shooting Settings 1" and then to "Grid line",then switch it off.
    I am attaching a photo for you.you might find it useful.
    Thank you
  • Anuj Joshi
    Anuj Joshi Oct 07, 2010
    I have looked this up for you again, since we were running into issues. This is what we need to do:
    Touch "Menu" --> Select "STANDARD SET Menu" (It has an icon that looks like a small briefcase) --> Select "Guideframe"
    Now, press DISPLAY/BATT INFO to turn off the framing grid.
    This will resolve your issue.
  • Anuj Joshi
    Anuj Joshi Oct 22, 2010
    A correction about "Now, press DISPLAY/BATT INFO to turn off the framing grid" that I said.
    On some newer models of your camera this button has a battery symbol on itself, no label.
    Let me know if the solution worked for you though.
Sony HDR-HC5 will not power on. AC adapter is working ok. I have an extra fully charged battery and it does not power the camcorder up either.
This is usually caused by a failed component in the power circuit within the camera. This will require disassembly and trouble-shooting to identify and replace the defective component and can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 17, 2011 | Sony Handycam HDR-HC5 Camcorder
Sony HC5 stuck in nightshot
This is most likely a broken or misaligned switch on the internal lens assembly and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jan 18, 2011 | Sony Handycam HDR-HC5 Camcorder
How do I turn on the grid on the D50
You don't. The D50 does not have the ability to display grid lines in the viewfinder.
May 15, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
I am having the same problem. My camera will not come on and I have changed the battery. It will not even charge. Does anyone know what is going on with this camera
If you can not power up with charger, your charger may be bad. If you can power up with charger, your camcorder battery terminal may be bad.
May 09, 2010 | Sony Handycam HDR-HC5 Camcorder
In custom setting, assigned the front function button to display framing grid. function button does not respond when pressed. am i missing something here? thanks
Aha! While pressing the fn button, turn the main command dial (the one on the back) to toggle the grid display.
Personally, I like having the grid, and used custom setting #D2 to turn it on the first day I had the D90. This frees the fn button for other, IMO more important things.
Mar 14, 2010 | Nikon D90 Digital Camera with 18-200mm...
My computer does not recognize my Sony hdr Hc5 camcorder. I cannot download my videos. I use firewire. I am using windows xp
Take a look at the firewire port on the camera, you should see four "pins" for lack of a better word. On mine, one of them was bent and I had to use a fine needle to bend it back in place, then presto everything works
Nov 19, 2009 | Sony Handycam HDR-HC5 Camcorder
I have a High Definition Sony Handycam - HDR-HC5. I am currently having major problems trying to use my firewire "i-link" cable to download the holiday tape onto my pc for editing. Each time the...
Go to manufacture's website. Find the download or support tab. Then look for the very latest drivers for your camera. Then download onto pc, double-click to extract and install the driver, then restart pc, Then turn on camera first, then start any programs you are using, then finally connect with usb/i-link/HD cable.
When pc doesn't recognize a device, it is due to the driver.
Nov 16, 2009 | Sony Handycam HDR-HC5 Camcorder
Any grid in nikon D200?
To turn on the Grid Display in the view finder...
Press Menu button, then go into the Custom Setting Menu (looks like a pencil). Select "Shooting/Display", then select "Grid Display", select "On" then "OK".
Happy shooting!
Sep 26, 2009 | Nikon D200 Body Only Digital Camera
Sony Handycam  HDR-HC5 Camcorder Logo
136 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
