Question about Kenmore Elite 45986 Front Load Washer
I have an Elite HE3 that is showing f21 problem. i have unplugged it, turned it back on about 3 times. They can not come to fix it for a week. Can u help?
    President:
  • 1,430 Answers
This usually indicates the drain pump filter needs to be cleaned out. Try this link you might be able to cancel the service call cleaning a drain pump
Posted on Oct 06, 2010
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 05, 2012 | Dryers
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
Front load he3 kenmore, control panel had an F now is locked up! Have unplugged for 30 min. no change
I just experienced a similar problem, getting an F21 error and 5d.
F21 error was a clogged drain. Unplug firest, then remove the lower front panel (it may be from the back panel) and look for a drain valve. unscrew and clean out good. I found approx $6 in change, keys, bobby pins, hair clips, etc. then put all back together and run a cycle empty. Save myself $250 I dont have and did it myself. This website is wonderful.
Denise
Dec 17, 2010 | Kenmore Front Load Washer
Kenmore elite he3 turns on but shuts off after 3 to 4 min.
it sounds like the relay on the board clicking off the board mybe faulty
Nov 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Buttons on Kenmore HE3 washer not working. Can only get delicate cycle to work and options on right hand side (water temp, spin speed, etc) not working.
I have the same problem. It started a few weeks ago. I did get it to work for a while by unplugging from the wall outlet. When you plug back in, you can choose one clcle and it will work. I repeated this 3 times and it went back to normal for 3 weeks until today. Trying to find a true permanent fix. unplugging and replugging resets something, will work temporarily
Jul 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE3 washer won't spin during rinse cycle...
possible door lock failure fdl/error code f-11- maybe f-2 pump,,,
Dec 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
Jul 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
222 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
