Question about IBM DS3400 (172641X)
Kindly help me with the Steps for replacing the Battery in IBM Disk System DS3400 : What I know is : Using IBM DS STORAGE MANGER 1) Under Support > Manage Controllers > Place Controller Online or Offline. Set Controller A (Which is the controller with the Old Battery) Offline. 2) At the back of the DS3000 Pulling out Controller A 3) Relpace the Battery, and replace the Controler 4) Place the Controller back online 5) Reset the Battery's Age in DS Storage Manager under .. Tools > Change Battery Setting Your help (recommendation) will be realy appreciated if I need to do anything more than this. A liitle bit of troubleshooting steps will also be appreciated. Reagards, Ravi.
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: IBM Total Storage DS400 I just did a ot sway
Hello there, I am a former IBMer that worked with storage arrays all the time, but I am confused on your issue here. I think you may have missed a few characters in your first couple sentences here:
IBM Total Storage DS400I just did a ot sway replacement of a failed controller.... IBM ServeRaid mgmt displays the same same failed controller status.
So have you replaced the failed controller? Sometimes you need to remove the definition from the system of the one controller and re-add it for it to recognize, but shouldn't need to.
Let me know some more info and I can definitely help you here.
Thanks Tim
Posted on Sep 10, 2010
OK, things that may cause this, The MotherBoard has developed a fault. To my mind, It is unlikely that TWO RAID controllers will go "Faulty" simultaneously? You need to test them BOTH to isolate the problem. and see if indeed it is the actual controllers?
What you need to do, is check those RAID controller IN ANOTHER system, and see if they are even functional? IF they are, then this more points to a faulty MB. Also check the Power Supply unit too, I have seen misbehaving PSU's cause RAID Controller problems.
Although they are "Hot Swap" that still doesn't mean that they haven't gone faulty from the motherboard, removal/ insertion?.
Also Check the RAM, if this faults, it may interfere with the controller.
Posted on Sep 22, 2010
What is the maximum Storage space that a IBM x226 Server can be scaled
6 x 300GB (largest available U320 SCSI HDD Capacity) = 1800 GB
Mar 26, 2015 | IBM Computers & Internet
Ds battery problem
Ok I know what has gone on here as it had happened to my DS-Lite as long as you bought a genuine DS from here in Oz or which ever country you live in and not 1 from China Etc as 99.999999% of DS consoles from China Etc are fakes
First Of all the problem is that the battery pack has failed completely the molecular structure of the battery is breaking back down into it's original state and when you recharge the battery pack it can not excite the molecules enough to completely charge as some of the molecules are dead and such will decrease the performance of your battery. You will need to buy a replacement battery pack or as it is a new console it should be covered under warranty as on a full charge on my DS Lite I can play for 15 hours+ non stop playing.
Ok the fix is very easy all you need is a small star screwdriver.
Step 1. Take the small star screwdriver and undo the screw that holds the battery compartment closed and take off the cover.
Step 2. Take out the old battery and set aside for proper disposal.
Step 3. Place the new battery in the battery compartment it should only go in 1 way.
Step 4. Replace the battery compartment door, replace the small screw and tighten.
Step 5. Charge the battery pack until light goes out.
Step 6. Play away my friend as now you should have fixed the problem.
Please Note that the time difference between consoles playing time depends on the actual ds console.
DS & DS-Lite are your better performers battery wise at up to 19 hours continuous play.
DSi to the current DSi-XL 3DS will vary from 3 to 6 hours due to the extra power needed to run the cameras etc.
Jan 25, 2013 | Nintendo DS Video Game Consoles & Games
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
How to format a new seagate external hard drive
Hi josernld
Formatting your drive for Windows Vista
STEP 1: Open Computer Management like this:
  1. Right-click on the Computer icon.
  2. Click Manage.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
STEP 2: In the pane on the left, under Storage, click Disk Management.
STEP 3: Right-click the drive that you want to format-be sure it's the correct drive-then click Format
STEP 4: To format with the default settings, in the Format dialog box, click OK, and then click OK again.
Formatting your drive for Windows XP STEP 1: Open Disk Management like this:
  1. Right-click on the My Computer icon.
  2. Click Manage.
  3. In the pane on the left, under Storage, click Disk Management.
STEP 2: Right-click on the drive you want to format. Be sure it's the correct drive.
STEP 3: If you want, you can type a name for the drive in the Volume Label box. This is an optional step.
STEP 4: Click the file system that you want to use in the File System box. You can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
Note: Before changing the default allocation unit size please refer to Microsoft Knowledge Base Article 314878.
STEP 5: Click OK. When you're prompted to format the drive, click OK again.
Formatting your drive for a Mac STEP 1: Open Disk Utility like this:
  1. Click Finder.
  2. Click Applications.
  3. Click Utilities.
  4. Click Disk Utility.
STEP 2: Select the drive you want to format. Be sure it's the correct drive.
STEP 3: Go to the Partition tab.
STEP 4: Click on the Current Volume Scheme drop-down menu and select One (1) partition.
STEP 5: Click Options. From the Partition Schemes provided:
  • Click on the GUID Partition Table radio button.
    --OR--
  • Click on the Apple Partition Map radio button.
STEP 6: Click OK. Select other options as desired (e.g., Volume Name, Format, etc).
STEP 7: Click Apply. The Partition Disk screen opens.
STEP 8: Click Partition. At this point, the volume dismounts from the desktop and the drive is partitioned and formatted.
Note: When Volumes are created, Time Machine may open, asking if you would like to use the volume for backups. Click Cancel to proceed.
STEP 9: When finished, select the Disk Utility from the Apple Menu and choose Quit Disk Utility.
Feb 17, 2011 | Seagate Computers & Internet
Ibm bladeCenter -S storage one hdd offline .how to forcely online
It probably is "offline" because it is "dead", and thus cannot go "online".
Replace the disk-drive, and the replacement should go "online", automatically.
Jan 23, 2011 | IBM Bladecenter H 88524XU Hard Drive Array
We forget the ip address for the MGMT port, we changed the default one
use arp .
find the mac address and then use arp to assign an ip address to the mac address . the you can enter the web front end using the ip address you assigned to the routers mac address and then find out or change your ip address. might not be any use to you
Mar 03, 2010 | IBM System Storage DS3400 Dual Controller...
Do you know how to reset the operator/admin passwords on an IBM DS 400? Cable didn't work.
System (BIOS) Password Reset
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Oct 06, 2009 | IBM TotalStorage DS400 (13N1846) 146 GB...
Having a trouble with my DVD-ROM - IBM ThinkPad T42
Internal the pickup assy. (the laser) there are three components that read the discs, one for DVD one for CD and one for the DVD-ROM its likely that the DVD-ROM laser has gone out. Take the drive out and get the part number and look it up online on ebay or the like :-)
Sep 13, 2007 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
IBM DS3400 (172641X) Logo
804 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
