Question about Ovens
Oven is running 75degrees hotter than the thermostat is set on-where do I adjust
  • Ovens Master
  • 3,463 Answers
Most thermostats are not adjustable on ovens, if you are in the u/k, then there is little you can do except change the stat, if in U.S.A, I believe some oven stats are adjustable, but not very many, it is not something I would recommend.
Posted on Oct 06, 2010
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
Inconsistant oven temperature
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 25, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
The problem is that the oven seems to get hotter and hotter as if the thermostat doesn't cut out, i.e. i was cooking braising steak yesterday temp set between 150 -100 this just boiled over. so i had to...
You are quite correct in saying that the thermostat is faulty.
Only solution is to replace it with a new one.
This should solve your problem.
Nov 29, 2009 | Belling Ovens
Oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
May 09, 2009 | Ovens
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
