Question about Xerox XG-91D 19" LCD Monitor
XEROX Monitor Product No : XM3-19W Model No: 900W Power: AC 100-240V 50/60Hz 1.2A Problem : " RGB Analog " When Starting the monitor afte 3 second display and then Black screen.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Xerox Master
  • 848 Answers
XEROX Monitor Product No : XM3-19W Model No: 900W Power: AC 100-240V 50/60Hz 1.2A Problem : " RGB Analog " When Starting the monitor afte 3 second display and then Black screen? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 003 190DTLB5 BH Xerox 860 AB0 190DTLB5 PSH Power Supply Backlight...
Posted on Feb 28, 2015
  • 11,361 Answers
Common failures in LCD monitors are due to bad caps as hown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 06, 2010
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
https://www.youtube.com/watch?v=rkYJS2KhnTc
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ...
Amazon.com: Ac Dc Adapter Charger for Xerox Model 900 ...
www.amazon.com > ... > Monitors
Amazon.com, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
Nov 23, 2015 | Xerox Computers & Internet
My monitor displays analog rgb then goes to blank black screen?
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 04, 2014 | Xerox Computers & Internet
I have a Xerox XR6-19W 900W monitor; what sort of dvi cable should I get?
Tries websites like Amazon.com,EBay.com have very fair prices on DVI cables.Both of these websites have all shorts of DVI cables.Just enter the products names and sub names and numbers view all the DVI cables for your used and fits for the DVI cables for the products.
Mar 06, 2013 | Computers & Internet
Installing new Samsung BX2250 21.5 widescreen monitor, don't have the appropriate DVI outlet on my computer to match HDMI to DVI cable supplied with unit. Monitor is stuck on "Check Signal Cable...
Your monitor has Analog RGB, DVI and HDMI inputs. Any other hook ups will require additional cables and/or adaptors. It also has 2 additional audio inputs. I can't answer your question without knowing what kind of outputs you do have on you computer system. Most desktops have DVI out and would probably be your best bet using a DVI to HDMI adaptor with a HDMI cable out to your HDMI in on your monitor.Rgb cable would use svga out on your computer. The best way to get an answer would be to let me know the make and model of your computer system with avaiable outputs, if you know what the outputs are or, repost with additional info included.
Dave
Apr 30, 2011 | Samsung Computers & Internet
Computer will not recognize
Double-check to see if the cable is properly attached and the monitor is set up for DVI(digital) or RGB(analog) depending on which cable it is. Or you can set it to Auto, that normally works.
If you still cannot get a picture try a different monitor or verify the computer is starting up. Sometimes if you fondle with the memory or other internal components the video will not show, thus the computer is not starting at all.
Feb 19, 2011 | X2Gen MG19MY 19" LCD Monitor
My monitor will not come on. the powere botton is flashing blue
Which model 900w or LE1936 ?
This info is usually on a sticker to the side of the stand.
If the 900w: You problem is probably that the capacitors on the power board have gone bad and need replacing. May also have transistor problems.
You would have to open it up to get a better idea.
I can probably tell from a picture.
If it is the LE1936: then it could be a similar capacitor problem, but it is rarer on this model than the 900w
Also on this model, there is a voltage regulator on the vga-dvi board that tends to go bad.
email bammbamm@ptd.net
Nov 03, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor says Analog RGB 1024 x 768 / 85 Hz Out of Range
install an AGP card into an AGP slot. use 8X AGP card then you can see high resolution because internal display card does not support to high resolution
Apr 02, 2010 | Xerox XR619DW Monitor
I have a proview monitor PL926WBI Model 900W
It seems to be that something gets hot inside after a few minutes of operation of the monitor. So I placed a small fan so that air flows thru the monitor and that did it. What gets hot inside , I don't know.
Oct 25, 2009 | Gateway FPD 1510 15.1" Flat Panel LCD...
I was given a Xenon flat screen monitor. The back has 4 usb ports and 1 usb input and an analog rgb port. It came with no cables. Can I just use a usb cable or do i need the analog rgb cable? Also when I...
The USB hub/connections cannot be used for driving the monitor... It is only an extra feature so that you can connect USB devices (such as a mouse & keyboard or flash drive) at the monitor instead of the computer ports.
You must use the RGB/VGA connection to use the monitor.
When you turn ON the monitor, it should "announce" itself with a logo...
When you were given the monitor, were you told that it works?
Please connect the monitor and comment back...
Thanks!
Sep 10, 2009 | Computers & Internet
Monitor turns off after 4-5 seconds
hi every one, i hope this helps and am proud to say/or not that i am now using my philips php-19x (aka proview 900w/Mag LT916s Model 900p/ Xerox) and yes turn on the monitor 2 seconds screen goes black and the blue power light stay lit, but if you shine a torch onto the screen you can see the lcd display is working, and if you turn the power off and on the cycle starts again, like most of us we checked the web to no avail, untill yesterday. I have been playing with this monitor for 3 months on and off after a kind fellow gave me this monitor for free on uk freecycle and of course i checked all the caps on the psu/inverter pcb and more components all seemed fine checked the ccfl lamps by taking them out of the lcd panel (15 minutes to dismantle) both lamps where fine not orange, a nice bright light, and knowing that if the monitor started woking ok and the back lights did not fail it would run like this for ever until you turned the monitor off / video blanking so i was convinced that there was no fault with the psu/inverter board, and as i stated i found the solution at last (yeh) and here it is many that's to all on the bad caps forum and of course the main man -----barry wilkins-----
Re: Mag LT916s Model 900p 19" LCD dropping like flies
I have got to the bottom of this ,after I got one of scopes out (PM 97) the output of the TL 494 IC was disappearing .The IC seems to crash easily ,I think the oscillator on pins 5&6 actually stops.
I cleaned the whole board with an aerosol of PCB cleaner and heated up the PCB up with a small craft heat gun to quite hot .
I fitted a 0.01 mfd capacitor across the IC pins 12 to 7 to decouple the VSS supply ,because I felt the cause of the IC stopping could be interference based
The monitor now runs for all day with no sign of the backlights cutting out.
I found out this LCD display was made by proview.
Barry Wilkins
john r uk.
Sep 05, 2008 | Computers & Internet
Xerox XG-91D 19" LCD Monitor Logo
942 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
