Question about Price Pfister 048NK00 Contempra Double-Handle Centerset Lavatory Faucet wit
Working on my Price Pfister 048nk00. Faucet was manufactured in December of 04. Purchased and installed in summer of 05. Observation: Cold water side has developed a slow-drip leak. Removed handles from both sides. Hot water side is clean and looks almost new. Cold water side has all sorts of a black, moist, but a sandy consistency, type of deposit around the cartridge (it's not mold). Questions: What do you think this is? Can I solve the cold water leak by merely tightening down something, or is this a cartridge replacement issue? If a replacement is necessary, is there a site you can direct me to that has step-by-step instructions, or a site that has a manual with a series of illustrated steps? Thanks.
SOURCE: handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Posted on Feb 20, 2009
gary1121
  • 332 Answers
SOURCE: installed a new price pfister two knob kitchen
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Posted on Jun 28, 2009
co7196
  • 3433 Answers
SOURCE: My water supply has little pieces of grit that
'DO NOT REMOVE"! lol JUST KIDDING. >You may need to remove again to find out why the valve seat is not sealing In fact, expect that you will. The grit is white in color? did you see any special washers or seals in the DNR zone? wHEN REINSTALLING THE VALE BODY, YHE STEM SHOULD BE ALL THE WAY OPEN . cLOSE THE VALVE ONLY AFTER ALL IS IN PLACE. AND YOU NEED An INLINE STRAINER IN YOUR WATER SYSTEM.. gOOD lUCK _nED_
Posted on Sep 27, 2009
  • 41 Answers
SOURCE: New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
check if any valves are not fully open first. if its a replacement of one that was working fine then the taps are most likely duff
Posted on Mar 03, 2010
  • 10865 Answers
SOURCE: I have a Price Pfister
Hi adheinen. In order to remove the side sprayer and hose from the diverter tee you must push the hose connector into the diverter and then push the grey ring in. Then pull out the hose connector. Here is a video showing exactly how this is done. Joe
http://www.pricepfister.com/about/diverter.aspx
Thanks for choosing Fixya!
Posted on Nov 27, 2010
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
Just purchased the Price Pfister 42-YP. The hot water has limited water - just a trickle. What can i do to adjust?
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Aug 31, 2010 | Price Pfister 42-YP0E Ashfield Single...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
The cold water handle is frozen in place. When I swap out the hot handle with it, it turns fine. How can I, or can I, unfreeze this frozen faucet handle? Model is 048nk00
Can you soak it in a type of penetrating oil to maybe free it up. Once freed up they make a grease for stem's maybe apply some to stem for smooth operation.
Aug 09, 2010 | Price Pfister 048NK00 Contempra...
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Jun 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister 048NK00 Contempra Double-Handle Centerset Lavatory Faucet wit Logo
90 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
