Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Washer won't drain. Water remains in bottom of washer after cycled is complete.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Sometimes washer will not drain completly. leaving clothes soaked after spin cycle. sometimes suds also remain.
either discharge hose is stopped up or washer drain pipe backing up or possible water pump on washer going bad but i would really lean towards the hose or drain to the washer
Jan 23, 2011 | Kenmore Washing Machines
My dishwasher won't drain completely in the last cycle so in other words water remains in the bottom of the washer. Don't know how to take it apart and clean out.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Dishwashers
1. washer will not proceed to next cycle 2. water remains in washer, and can't open 3. not draining 3 won't drain even when manually advancing cycle
This is the drain cycle and it shows that the drain is not working at all. So make a test with the washer on in the drain cycle and test the voltage on the drain pump./valve, if voltage ispresetnthe drain valve/pump is faulty or cloggged. If there is no votage then the program controller is faulty. you might ahve to check if the controller can be rectified or replaced as a whole.
Sep 24, 2010 | Splendide 2000S Vented Washer/Dryer
Kenmore HE2 does not drain after first load.
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open. After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
Water remaining in washer after completed
any error codes maybe f21,take the bottom panel off, you'll see the pump on the right hand side,use a pair of plyers to unscrew the middle part of pump,if you have a shop vac turn the middle part counter clock wise slowly when water starts coming out vac it up,also put a towel under the pump to catch water,when it's drained unscrew the middle part all the way and take it out and clean out the pump,feel around inside to make sure nothing is stuck in the impeller of the pump, try blowing through the other end of drain line to see if there is a block in it,put it back together and run it,put it on spin drain and make sure water is pumping out the drain line,if not the pump could of been damaged and you need to replace it
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have stacked version. Won't drain completely in spin cycle. Water remains in bottom of washer.
Might be something in the pump, I have found socks and underwear in them. here is some repair pix with a repair manual throwed in.
REPAIR PHOTOS AND MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 23, 2009 | Washing Machines
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
385 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
