Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
My KA drawer dishwasher won't stop beeping and running motor
betz73
  • 298 Answers
SOURCE: fischer & paykel dishwasher #DD6031
make sure there is no food clogging the screen on the bottom of the dish washer.
Posted on Oct 06, 2008
  • 7 Answers
SOURCE: Both drawers Fisher Paykel DD603i start Beeping/Draining
the unit as had a lieak your it thinks it as first un plug the unit then try taking out the bottom draw (pull it all the way out then at the bottom front on both sides there is to clips push both clips in and pull the draw it wiil leaft of it runners push the runs back in out of the way then the can see under the in the base of the unit if the can see water or damp dathch plz call an enginner as ther is 5 things it can be
if not water you will see a grey plactic cover in the bottom back right the main pcb is in there witch has a water sencer on it if you fell up to 4remover the pcb and wiep the two prongs that are on the end of it as wiep there it was siting then put back as it was ps the dont need to take any wires to repalces the draw pull the to runners back out sit the draw on them then clothes the draw but re open it and give the to cilps a lite pull to make sure they are locked back in to places pulg it back in and try it if this dont work plz call an enginner as there is 3 pcbs in this unti that will need cheking
Posted on Jul 23, 2009
SOURCE: Fisher Paykel double drawer dishwasher DS6031
you have an overflow leak problem....shut off circuit breaker or pull fuse....let it dry out for up to 4 days; hopefully overnight; peak under dryer and feel metal drip pan and if wet you might be able to dry with a hair dryer...WHY? the lid did not seal when you put cycle on...the lid lowers and you had something..typically too bid glasses on second shelf that was above the seal lip of the tub...stack correctly after this and no worries...
Posted on Jan 05, 2010
pappapumpdaf
  • 635 Answers
SOURCE: Dishwasher not getting enough water in either
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Posted on Mar 07, 2010
SOURCE: Both drawers are stuck in the on position, both
The water sensor is malfunctioning. It believes that there is still water, so the pumps run and the washer will not continue on its cycle. replace the water sensor, or dry it out so it functions properly
Posted on May 30, 2010
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Have a Fisher & Paykel two drawer built in, each drawer will start running, but stops many times thru the cycle and starts beeping.
The dishdrawer is a very sophisticated dishwasher and is very sensitive to dirt collecting inside and in the drain hoses. My suggestion would be to first clean the drawers from inside with damp cloth, especially around the top panel. Buy Finish dishwasher cleaning kit (one for each drawer) from the supermarket. Select longest cycel on dishwasher and run each drawer with the cleaning kit inside as per instructions on the kit.
See if this makes any difference.
Dec 11, 2012 | Fisher and Paykel Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
May 15, 2010 | KitchenAid 23 in. KUDD01DPPA Stainless...
We have the Q 2 drawer dishwasher stopped working.
the f1 is the flood sensor....a leak has accured....either a dish to larger or lid motor has failed. will need to remove bottom drawer and soak up water and then let air dry for a day or two....turn off the breaker this will keep it from beeping and running the pumps....after drying unit will run, but need to watch the dishes you put in drawers.
Jun 30, 2009 | Fisher and Paykel DD605HSS 23 in. Built-in...
My Fisher and Paykel dishwasher will not keep running.
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the door is open or closed. Wipe these areas with a clean dry cloth...Give it a try
May 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher Dilema
You need to remove the bottom drawer and dry out the water with towels and a hair dryer when this is done it should operate normally. most likely when you pulled out the drawer the water sloshed back and out of the drawer making the dishdrawer think it was flodding turning on all drain pumps. If you look at the back of the drawer about two inches from the floor you will see an oval hole off center to the right. That is where the water got out.
Jan 10, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
183 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
