Where do the filters go in HEIL gas furnace Mfg# 697A
    President:
  • 1,515 Answers
Hi, If this is a split system, look in the indoor unit to see if it is at the top, or bottom. This depends on if its a down flow or up flow unit. Sometimes they are in the hallway ceiling behind a grill that drops down. Walk through your home and look up for a grill. Look near the furnace down low also, they will put them in lots of places, but usually near the furnace. If no grill any where, it will have to go inside above or below the blower motor. You should see the opening where it lays with the arrow on the filter pointing in the direction of the air flow. If you have no grill, and there is not one in the furnace, you need to put one where the air is coming back to the unit inside to catch the dust. Please let me know if you found it and please rate me on this as I know you will be kind.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Oct 06, 2010
Furnace filter - Amana AMh950703BX... how do i change it?
do a search for the mfg and see if you can download a manual
or put the name and the model number in a search engine along with words user manual and see if you can find one
Mar 19, 2013 | Amana GMH950453BX Gas Furnace
How often should filters be replaced on a Heil Ultimate II gas furnace? Once at the beginning of the "heating" season and once at the end - would that be sufficient?
Hello, it depends what type of filters you are using, if you have the pleated filters such as the 3m brand they should be changed every three months If you are using the blue filters they should be changed every month.
May 03, 2011 | Heating & Cooling
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Dec 30, 2010 | Water Heaters
Furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Oct 17, 2009 | Heating & Cooling
Heil Gas Furnace Filters
the filters will go by your blower compartment remove the doors at the furnace and look where the sheet metal opening meets the furnace
Jul 17, 2009 | Heating & Cooling
Where do install a Heil furnace filter?
MAYBE IT DOES NEED IF THE FILTER IN THE COLD AIR RETURN GRILL MAKE SURE THEIR IS NO FILTER IN THIS FIRST , AS 2 FILTERS ARE NOT BETTER THAN ONE WHEN COME TO ELECTRIC FURN AND H/P ALSO IS THIS A UP-FLOW ,DOWN FLOW OR HORZ MEANING AIR #1 RTN IN BOTTOM DISCHARGE COMING OUT OF TOP OR#2 COLD AIR COMING IN TOP AND DISCHARGE OUT OF BOTTOM OR #3FURNACE LAYING SIDE-WAYS AIR COMING IN ONE END AND OUT OTHER THESE WOULD DETERMINE FILTER LOCATIONS
Nov 19, 2008 | Water Heaters
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
