Question about Ovens
Oven is whirlpool model RBS305PDD6 and keeps beeping. We unplug it and when we plug it back in it beeps again.
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
Macmarkus
  • 2605 Answers
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Posted on Dec 07, 2009
  • 30 Answers
SOURCE: Kenmore oven keeps beeping, shows F7 on display.
Please, don't replace anything before trying this first! The insulation in the ribbon cable is poor, so the conductors in the cable become crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. There, problem solved, and you didn't have to buy new parts.
Posted on Dec 08, 2009
SOURCE: beeping F11
F11  is a keypad short. This was actually a simple fix when I got into it. Take off the top rear panel. You will need a drill driver or #2 square drive. Once inside: the EOC is held in by 4 screws. Remove those and pull out the EOC.
My diagnosis on the problem is this: The keypad connection to the EOC is the thin plastic serial connector on the top of the unit, looping to the back. What I figure is that this plastic must have the  tendency to warp under the influence of heat and  thus reduces the good connection to the serial input on the EOC. There is a black plastic connection protector on the input side of the serial connector at the EOC. Gently pull this off and pull the serial connector out and give it a good cleaning. Place the serial connector back in the receiver and replace the connection protector back on. ( tricky.  if you have ever built a model or soldered anything you will be fine.)
The serial connection will need some pressure on it  to make a good connection if it is warped. My solution to this was to run a plastic cable tie thru the small holes in the top of the EOC. tighten the cable tie over the serial connector, pressing it to the top of the EOC. This gives it a good pressure on the input pins in the connection input.
Now plug the unit back in. You should have full function of the keypad. If not, it may be another issue with the keypad or EOC.  This was a solution I happened to stumble on and it may not work for everyone but giving it a shot means you might save 170 dollars in parts not including the labor.
Posted on Dec 16, 2009
fixyourboard
  • 310 Answers
SOURCE: Displays F2 E6 on Whirlpool RBD305PDQ10 double
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
www.fixyourboard.com
Posted on Mar 05, 2010
My "Probe" keeps beeping. I tried cancelling...no help. Tried heating oven at 400 degrees as suggested by one person (to take out the humidity....)for 15 mins. Helps for awhile but then starts beeping...
The top oven the stove will lift up,with effort,and fold back,unplug first,and see if it needs cleaning and the sensors are in there I think,clean them,try to unplug it to reset,see if that helps.
Nov 20, 2009 | KitchenAid Ovens
Oven keeps making a BEEPING sound - only way to
This will occur when there is a control fault detected. have the oven control board replaced asap.
Aug 20, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Nov 30, 2007 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
