Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome dvd 300
I am having a problem when I hook up my dvd player to the tv. I can hear a sound coming from the dvd player but we cannot see the picture on the Tv.
My husband got on the internet and someone else was having another problem and we tried their solution and it worked. Thank you for the help . The Solution was to hold the stop button for twenty seconds and it worked.
Posted on Jun 01, 2008
What is required to hook up my cyberhome 300 to my television i was given the unit with only the plug in electrical cord no other cords what else do I need to get to make it work thanks patrick
red/white & yellow cable wire....connect to tv/monitor by color...depending on what jack u plug into on tv (to watch you will have to tune that ch 3/aux/video)...
Jun 23, 2010 | Cyberhome CH-DVD 300 DVD Player
Connecting my dvd player to my lcd hdtv tv
Do you already activate the progresive scan function,if not put it on.
Jun 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Sound
Sounds like a cable problem. I get this a lot with my coaxial cable, it takes a little turning or playing with to start working. Use an optical cable if you have the option, they are more secure, or if you don't mind going analog use the red white rca cable. Either that or replace the coaxial, if you're using one. If your amp/TV, whatever you're connected to, has a vacant audio input jack to switch to, try that as well. Good luck
Jun 06, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
