Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
The heater has been setting for a long time with fuel in it. It will not light. Is there away to check and see if injection port is plugged?
  • All-Pro Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
97 Chevy Suburban 5.7 liter vortec 62lbs pressure at Schrader valve. Fire at spark plug. Sprayed starter fluid down throttlebody. Immediately pulled spark plug and they were dry. I'm lost please help
What fuel injection system does it have ? Center port fuel injection or fuel rail injection ? Are the injectors being controlled (turned on) by the PCM - engine computer ? Do you know how to test injector drives ? Injector driver is a transistor inside the PCM , that controls the on/off time of the injectors . How to test fuel injector circuit with basic tools open control wire How to change SPIDER INJECTOR on Chevrolet V8
Jan 28, 2017 | Cars & Trucks
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
Drove our 2002 F550 Diesel...shut it off and it would not restart. The dash lights do not come on and the motor cranks fine.... just won't start. Robbie
If the dash lights don't come on then the ignition key switch is no powering the electronics and the diesel pump cutoff solenoid - there is no way for the engine to start.
You need to replace the ignition switch
http://www.newfordparts.com/seccat/f550-2043/2002/ignition-switch-30593/22/30593/
For that the steering column will have to be dismantled - it's a quite complicated job and if you have never done something like that before you should leave it to a repair shop. Anyone will do, no need for a dealer's shop.
Jul 13, 2011 | Ford F Cars & Trucks
My 98 mazda lantis idles up and down once the vehicle gets hot i cleaned the trottle body changed spark plugs changed plug wires change distributor cap the rotor seems to be fine what else could this...
It is a fuel problem. The engine is 'hunting' and needs to be set up in a diagnostics machine, especially if it is fuel injected. If it is normally aspirated you might get away with blowing compressed air through all the accessible channels and ports, including the volume control screws. Screw them all the way in, counting the number of half turns so that they can be reset to the same setting.
Jan 16, 2011 | 1998 Mazda Protege
I have a 1997 Dodge Dakota 3.9 v-6 It dies while driving and at the light and it sometimes start right away and other times it takes 15mins. Replaced the brain twice ,replaced the pick-up coil, all spark...
Have you relapced the fuel pump and filter? Take it to a garage and have the fuel pump pressure checked. It very common for fuel pumps or a clog in the line to cause this.
Oct 08, 2010 | 1997 Dodge Dakota
1998 Ford 460 Fuel injected Bounder Motorhome engine light proble
Plug the computer on to the port located under the dash on the drivers side to get a code reading. It sounds like a 02 sensor about to go bad. If you get a 700 area code, its a transmission sensor code.
Jun 12, 2017 | 1998 Ford F250 SuperCab
My nissan navara D22
Hi james, you might have air in your injection system. ussually this air pocket could be corrected by bleeding the system; or, your fuel filter is clogged. First the filter, if your fuel filter is directly attached to a hand pump, and your filter has a sendimentary bleed port at its bottom, drain this first. Then, after its drained, close the drain plug. Next is to look for the fuel return bolt on the injection pump(usually it has a "out" word etched on it) and usually uses a 17mm hexagonal head. Loosen the bolt and slowly remove it. Take care, and watch orientation of the two copper washers that are used for gasket. You might also find a filter screen attached to the bolt on some injection pumps. Anyways, if there is no filter screen, re-screw in the bolt(remember the copper washers) but do not tighten it just let it loose for a while. Now for the sweaty part, using the hand pump, pump  the fuel in until the return bolt spits out fuel. You will see bubbles on the first few pumps but do not stop until it bellows out pure and clear fuel w/o bubbles. If you attained the goal, stop pumping and screw the bolt shut. Wipe-off excess fuel from the injection pump. Try starting the engine. when the engine turns over let it warm up for a while the with, again, with your no. 17mm open wrench, try loosening the injector feedline one at a time(while the engine is running).Watch out for squirting fuel, your engine might rattle a little but it will be fine, just let the fuel flow a few seconds then re-tighten the nut. Do this on all 4 injectors. Let the engine run a few minutes then shut it down. Let it completely cool down then re-start it. Also try checking glow plug(or heater plug) condition. If one glow plug is busted replace all 4 at the same time with the same brand. this would help to keep the engine attain a 1-click engine run.
Hope this helps.
Sep 29, 2009 | 2005 Nissan King Cab
Hard to start in the morning. Also stalls
This sounds like a fuel pump check valve problem, if the fuel is not kept in the filter and lines by the check valve it drains back into the fuel tank and causes the kind of problems you are having, you can check this by hooking up a fuel pressure guage at the test port on the fuel manifold that supplies fuel to the injectors, run the engine and shut it down, note the fuel pressure at shut down (with the test guage hooked up), walk away for an hour, come back and check the pressure, it should not have dropped more than 5 PSI You can buy a universal fuel injection pressure tester for about $25.00, cheaper than having a shop run the test. If the pressure drops you found the problem, bad news is the check valve is in the pump, the pump is in the gas tank.
Oct 16, 2008 | 1994 Buick LeSabre
Cranks but wont start
Engine Cranks But Will Not Start
For an engine to run, you need three things to happen inside the engine. Compression, fuel and ignition, without any one of these components the engine will not run.
Basic Checks:
A. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
B. Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
C. Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
D. Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
E. Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
Jul 14, 2008 | Hyundai Motor 2002 Sonata
Doesn't start
1. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
2.Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
3.Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
4.Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
5.Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
Jun 16, 2008 | 2000 Nissan Quest
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
65 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
