Question about Car Audio & Video
I want to know what is the wiring diagrams of a intrepid es 1998
    Master:
  • 473 Answers
Go To Canadian Tire or your Dealership and ask for Electrical Diagram For your Car.
Posted on Oct 06, 2010
Where do you put antifreeze on 2002dodge intrepid
Terry, Add coolant to the reservoir located under hood, mounted by shock tower and fuse/relay center, fill to the full mark on side of coolant reservoir when cold, recheck after running and engine cold again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Add Coolant Dodge Intrepid 1998 2004 2000 Dodge Intrepid ES 2 7L V6
Auto Repair Replace Engine Coolant Radiator Overflow Bottle Dodge Intrepid...
How to Remove Dodge Intrepid Radiator eHow
Jun 26, 2016 | Cars & Trucks
1998 Dodge Intrepid ES and I am NOT getting power from the key to the starter?
check your wireing and also check to see if your key has not lost its memory
Sep 02, 2010 | 1998 Dodge Intrepid
1998 Intrepid, 2.7 engine - had problems starting at different times (turn over but sounds like it won't fire). Chrysler deal replaced crank and cam sensors as well as the computer. They returned it to...
When it die's check to see what's missing ! Spark or fuel pressure .Then diagnose which ever system isn't working . Check for B+ voltage at a coil and a fuel injector ,don't know how much you know about automotive electrical systems . If no B+ voltage the ASD relay maybe going bad . Do you know what a wiring diagram is , how to test electrical circuit's with a DMM - digital multi-meter ? No Start Diagnostic Basics EricTheCarGuy
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine size. Under system click on engine ,then under subsystem click fuel controls . Click search button then the blue links . When it die's check B+ voltage an ground circuit's , you have to find what is missing !
Nov 21, 2017 | 1998 Dodge Intrepid
1998 Chrysler Intrepid ES 3.2 Code P0731.
Check the connection to the vehicle speed sensor. You can check the vehicle speed sensor by using a voltmeter set at millivolt. Then pass a metallic object close to it. The sensor should induce voltage as you pass the metallic object close to it. If not replace the vehicle speed sensor.
Nov 23, 2009 | 1998 Dodge Intrepid
Need Diagram of water pump on a 1998 Dodge Intrepid 2.7,
the water pump is timing chain driven and to replace it requires serious disassembly of the engine. it is a 13 + hour job and is not for the casual mechanic
Apr 13, 2009 | 1998 Dodge Intrepid
No Start Replaced Cam Sensor Now Runs But Rough
I don't know if you have a coil pack or spark plug wires but this is what you need to check for the miss you can also try this website if needed for diagrams and instructions autozone.com or your local library
Mar 07, 2009 | 1998 Dodge Intrepid
1998 Intrepid random misfire
I have a 98 dodge intrepid with a 2.7. My car would run fine at times and then all of a sudden start to miss badly and the valves would rattle. The mechanic changed the cam shaft sensor and now it runs very well.
Feb 28, 2009 | 1998 Dodge Intrepid
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
