Question about Linksys Wireless-G WRT54G Router
How many volts output is the power cube? - Linksys Wireless-G WRT54G Router
    Genius:
  • 1,354 Answers
Hi
go to following link you will find your solution
http://homecommunity.cisco.com/t5/Wireless-Routers/Power-outage-Linksys-WRT54G-V2-2-Router-needs-to-be-totally-re/m-p/134056
Posted on Oct 06, 2010
    Guru:
  • 126 Answers
12 volt only
240 volt output of 3500 watt powermate generator measures 140 volts
Bad capacitor in the alternator field or a short in the rotor / stator
Nov 05, 2012 | Coleman Powermate Powermate 5000W...
Can I use an 18 volt universal AC Power Adaptor on Fujitsu Lifebook P7120 which is a 16 volt laptop?
With voltage step down power supplies, output power is more important than data plate output V (volts). V times output A (data-plate amps) equals output Watts (or VA) under normal load. If the voltages are close and the output watts (VA) are very close (one or two watts) you are in luck as long as the connector is same size; AND THE POLARITY (+ & -) IS THE SAME for the old and replacement unit!
Jan 17, 2012 | Fujitsu LifeBook P7120 Laptop AC Power...
I have a Skil Wrench Model #2238 Type 2 120 RPM 3.6 volts I've used it many times and now I have no power light out of the charger and trhe wrench does not work at all. I love the tool but I need...
I've the same problem. It's the battery inside. Due to the age the battery died. It's a special one with special dimensions. My tip: if you like it, buy a new one ...
Nov 08, 2010 | Garden
Power to Motherboard but will not bootup?
most likely a failed hard drive as all of the boot requirements are on it
Apr 24, 2017 | MSI 694T PRO (6309-470) Motherboard
How many parts in transformer & briefly explained
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
Apr 26, 2010 | Sunbeam Transformer (ICTRBA) ATX Full...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Gamecube, output problem.
There is no way to switch this back and forth, if the rca jacks work and the fr jack doesnot there is a problem extending from the game unit itself which works on a certain amount electrical current to maintain signal which is not required for digital/rca. check your rca connections, if they work then your problem is in the rf converter and it should be replaced and or just purchase a cheap switching unit that splits between the rf and the rca on channels 3 or 4. Good Luck and let me know what happens.
Fehdi
Jul 14, 2009 | Nintendo GameCube Console
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Oct 24, 2008 | Magellan Universal Ac Wall Power Supply...
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Sep 08, 2008 | Sony ICF-CD855VSIL Clock Radio
Linksys Wireless-G WRT54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
