Question about LaCie Computers & Internet
I have a lacie big disk extreme + 2.0 TB. I am using Win XP Home. Recently, I have been having problems getting the drive to boot. According to windows, I have about 850 GB of drive space left, so I don't think the drive is getting full. The problem seems to be intermittent. Also, when I do get the drive to boot, when I try to access it, the light starts to flash and I lose the boot. Is this a problem with the drive, or my PC?
    Brigadier General:
  • 10,406 Answers
> is this a problem with ... my PC?
Try connecting the drive to a different PC.
If you have the same (intermittent?) problem, then it is NOT your PC which is at fault.
I suspect that your unit is about to _permanently_ fail.
Make a backup copy of all your files, before it does.
Then, exercise LaCie's warranty to get it replaced.
Posted on Oct 06, 2010
LaCie Hard Disk Quadra Setup Assistant
try this link
http://www.lacie.com/support/drivers/driver.htm?id=10145
Aug 29, 2012 | LaCie Big Disk Extreme with Triple...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
Lights on nobody home
Well if it is less than 2 or 3 years old you could contact them to attempt a sawp out of the drive. Over that - replace the unit. IF you do - you might want to consider a duel disk enclosure so if a drive dies, your data does not. you can build one yourself (1 TB duel drives, Raid 1) for a total of 252 bucks, with good drives (Seagate - Barracuda) Yes I swear by the Seagate Drive. For off teh shelf they have worked very well in every application I have deployed them.
I've been burned by too many single drive failures - even when I have the data backed up it is still a royal pain.
Jan 25, 2010 | LaCie Big Disk Extreme with Triple...
Clicked "no access" on my Lacie
Just cocnect it on a computer and boot from a live cd, somethig like linux or erd commander, and copy your files to a nother drive than u can format your disc and reset the protection...
Sep 03, 2009 | LaCie Big Disk Extreme with Triple...
My LaCie 1T Big Disk Extreme just keeps clicking....
No do not throw it away buy another enclosure for it and take the driveout and put it into another enclosure you will have better results and a longer lasting drive and you be glad you did!
Jul 19, 2009 | LaCie Big Disk Extreme with Triple...
Pc not recognizing drive when turned on
Maybe this can help you:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Have you tried the disk on a different system?
Jules
Apr 02, 2009 | LaCie Big Disk Extreme with Triple...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Blinking Power Light
My Disk has been formated.Not recognized by Windows.How can,I reset the USB.
Dec 02, 2007 | LaCie Big Disk Extreme with Triple...
Computers & Internet Logo
93 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
