Question about Polycom HDX 8002 XL
I believe we have the Polycom HDX 8002XL model (or one closely resembling it). After many weeks of problems with the video pixalating, we were able to stabilize the system and videoconference with our sister company by using an LG monitor and by fixing the call transmission rate to 512Kbps. However, last week, the sister company changed over to a "Tandberg" system and now they can see and hear us, but we can only hear them (no video but our own conference room.) We connect through a "bridge" at the sister company and tried connecting through our own bridge and without a bridge but weren't able to do so. We adjusted the transmission rates; at 1920Kbps (the highest setting) we were able to finally see our sister company's conference room but everything was in a dark red hue. When we tried backing down the setting to 768Kbps, we just saw a black screen (as we had using 512Kbps). Same with a lower setting of 384Kbps. Are there known compatibility issues with the "Tandberg" system, and if so, how do we remedy this? We need to be up and running by next Wednesday at the latest. I am not an IT person; just an engineer. However, you can copy our IT people on your response at: mahlerko@westinghouse.com and ronald.bennet@shawgrp.com Frank Gavlak gavlakfj@westinghouse.com
I would buy your Polycom system from you and sell you a Tandberg system. I have factory and deal refurbished units and it would not cost much to upgrade.
Let us know.
Paul
Golden Gate Networks
(530) 615-0033
Posted on Oct 07, 2010
How to reset the password of polycom hdx 7000
You can use the hardware restore button on the Polycom HDX system to reset
the system in one of these ways:
• Restoring configuration-Restores the configuration, which resets most
system settings to default values.
• Factory restore-Completely erases the system and restores it to the
software version and default configuration stored in its factory partition.
If you follow this procedure while a USB storage device is connected, the
system restores from the USB device instead of the system's factory
partition.
The restore button is on the front of the Polycom HDX 9000 series system, as
shown in the following figure.
The restore button is on the front of the Polycom HDX 8000 series, Polycom
HDX 7000 series, and Polycom HDX 4000 systems, as shown in the following
figure.
The restore button is on the left side of the Polycom HDX 4500 system, behind
a wire mesh screen, as shown in the following figure.
Use a paperclip to press the restore button through the wire mesh covering
that side of the system. to reset the HDX Series system we can press the restore button over 15 second.
Feb 27, 2014 | Polycom VSX 7000 Video Conference
I need parts for and hdx shelving unit model 1701099
You can find all parts for this unit at www.apgparts.com.
Dec 09, 2013 | Polycom HDX 5-Shelf 18 in. D x 36 in. W x...
When i switch on the polycom hdx 7000 only logo is coming.but home page is not coming. so wht i do?
http://supportdocs.polycom.com/PolycomService/support/global/documents/support/user/products/video/hdxroom_ug.pdf
Here is the link for the PDF of the manual.  I would try every variation of holding the on/off button for several seconds and unplugging the machine for several minutes before re-plugging back in.
Mar 10, 2011 | Polycom VSX 7000 Video Conference
HDX8000 with ISDN
Please confirm if you have made video call or audio call. There is an option in the called basic mode, if it is enabled then disable and check. ckeck with service provider for the bonding option. Last option you can try SW upgrade
Jul 01, 2010 | Polycom HDX 8002 XL
Can we use IR Insted of RS 232 to control the HDX 7001 XL Model Pls replay
my passport key no:6800418409 plese give the passport photo copy pls
Feb 16, 2010 | Polycom HDX 7001 XL Video Conference...
Need advice on installing a Polycom 'Polyscan' video teleconferencing system
Some ideas based on your post/description:
It is very possible that the management/support software necessary to run your videoconferencing system resides or is installed in the PC based router that got burned. When you replaced the router with a NetGear, you simply provided an interconnection/distribution/forwarding/sharing of your Internet access to the different PCs of your firm but nothing to replace the server/management software for the Polyscan System. You have replaced only half of the PC based router - the router only, hence you have Internet acces but no video conferencing which is software managed which was installed in the PC half. Additionally, Polycom uses online Product Activation which might be necessary for your system to start working again.
Depending on the model of the Polyscan System that you have, it is also possible that you simply have to reconfigure the network settings of your Polyscan' System to match the new IP address of the Netgear (which might be very different from what the burned PC based router was using before). I understand that Polycom have several models (or series as they term it - PVX, TPX, RPX, VSX, HDX, and others). Would you pls post back with the series/model number that you are using?
Have you tried discussing your concern with Polycom Support? They might be in a better position to address this.
Hope this be of some help/idea. Pls post back with the Polycom system model that you are using.
Good luck and kind regards.
Nov 28, 2007 | Polycom (2200-30169-001) Router
Polycom HDX 8002 XL  Logo
339 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
