Question about Panasonic Microwave Ovens
I need to replace the bulb on a Panasonic NN-V453 microwave
  • Panasonic Master
  • 9,098 Answers
That's a UK model, so I'm not sure if it might be more complicated than US models.
If you don't have an obvious access panel (or one mentioned in your owner's manual) then the outer cover will have to be removed.
In some over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
If you still need help, I would suggest you contact Panasonic UK support here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 30, 2008
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
I need to replace a bulb, the glass cover and the bulb holder for a Panasonic Model NN K652BBPQ. Where can I order these parts please.
Panasonic.com appliance parts.com do agoogle search for panasonic microwave oven parts etc. the internet is your oyster the end result is your pearl
Dec 16, 2014 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
We have a Panasonic NN V453 microwave - but have lost the manual. We have already had the lamp replaced some years ago and the machine needs replacing. We want one with a similar capacity (which we do not...
Sadly we can not . You need to go shopping for yourself with some measurements of where you want to locate it , with an idea of what wattage you want also .
Sep 21, 2017 | Microwave Ovens
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Microwave panasonic nn v453 swiches off after a few seconds timer works on demonstration mode.has Magnatron failed ?
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
Jun 28, 2008 | Panasonic Microwave Ovens
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
