Question about NetGear RangeMax NEXT WNR834B Wireless Router
My Netgear WNR834B use to work till disconnected from power for few mins. No more green light or wireless blue light & is not connecting to internet or giving default gateway anymore Can you help?
  • 21 Answers
SOURCE: Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Posted on Dec 13, 2008
vincent721
  • 240 Answers
SOURCE: netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Posted on Mar 13, 2009
redhaze89
  • 854 Answers
SOURCE: Securing a Netgear WNR834B Wireless Router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 12, 2009
redhaze89
  • 854 Answers
SOURCE: wireless router
Here are some troubleshooting steps that I suggest you try: 1. Check physical connections. a. Connect the modem to the Internet port of the router. The Internet ?i? LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up. 2. Access the router's web-based utility. a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default. To reset the router: a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in. 3. Configure the router. If your Internet Service Provider is using a cable connection, please follow the steps below: a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button. If your Internet Service Provider is using a DSL connection, please follow the steps below: a. Click on Basic Settings. b. Select Yes for Does Your Internet Connection Require A Login?. c. Select Other on the Internet Service Provider drop down box. d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply. 4. Configure the wireless settings. a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number. Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection. f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle. 5. Power cycle. a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online. If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below: 6. Connect wireless computer to the router. If you are using Windows XP with Service Pack 1, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect. If you are using Windows XP with Service Pack 2, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router. If you are using Windows Vista, please follow the steps below: a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect. From the above configuration, please check if you can now access the Internet.
Posted on Jun 15, 2009
WiFiNut
  • 53 Answers
SOURCE: How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Posted on Jul 04, 2009
Wifi stopped working
power cycle. if it still doesn't work then reset to factory defaults and set back up again from scratch.
Aug 09, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
Wnr834bv2 power light is sometimes on in amber, then blinking green and I keep losing connection
Try resetting and then reconfigure the router.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 11, 2012 | NetGear WNR834B RangeMax NEXT Wireless-N...
Use a netgear wnr834b as a range extender
Range extender Have Become Important Part Of Our Daily WiFi Usage.
As Modern Technology Is Growing Everybody likes Faster And Longer Wireless Connectivity.
Extenders Mean Boosting And straightening the Wireless connection.
Today Here We will help you Find out How to setup Netgear range extender?
How to Setup Netgear Range Extender Mywifiext net
Jan 31, 2012 | NetGear RangeMax NEXT WNR834B Wireless...
Problems with our wireless devices connecting to the netgear
Do you have a cordless phone in the area transmitting at 2.4megahertz?
If you do, that is what is breaking your connection. I found this out by accident.
May 27, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Internet connection stopped suddenly
Switch off power to the modem, router and computer. Now switch on the modem first and let all lights on it to be stable.. Then switch on the router and let all lights on the router become stable. Once the lights on router are all stable, switch on the computer and then try to accerss sites.
May 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear wireless router WNR834B has died ... no power ... no connection. :-(
You need to return it if it is under warranty. If not you need to buy a new router. I suggest getting a Belkin.
Oct 21, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
48 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
