Question about Frigidaire FTF2140FS Front Load Washer / Dryer
I nid Frigidaire Front Loading Washer LTF2140FS Service Manual
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
SOURCE: Frigidaire Gallery Heavy Duty Front Loading Washer, FWT445GESI
If you access the bottom panel you can see the shocks mounted from the base of the machine to the tub. you will need to take the top panel off and you can see the springs the are mounted about 1/2 way in at the top and connect to the to off the tub
Posted on Nov 02, 2008
SOURCE: error code E70 on my Frigidaire front loading
The hot and cold water hoses were connected wrong to the washer.
Posted on Dec 23, 2009
SOURCE: Just want to know how to reset a Frigidaire Front
My 8 hour delay won't go off. Not sure how to get it to and the manual doesn't help at all. Can anyone advise? thanks.
Posted on Apr 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: moffat front loading washer user instructions/manual needed.
Head over tho the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
How do I repair my front load washer that seems like the water pump will not allow the water to drain?
did you check the water filter on the lower part of the machine to be sure it isn't stopped up?
Sep 25, 2014 | Frigidaire Washing Machines
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire front loading washer model FWT449GFS1
For a repair manual, contact Frigidaire directly.
Oct 07, 2017 | Washing Machines
I need a manual for the Frigidaire FAFS4272LW Front Loading Steam Washer
Hello Ann Todd - I located the manual on the Frigidaire website. Here is the manufacturer link and according to your model it seems like the direction of the door swing cannot be change. If you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data.
Feb 16, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Seal on front loading washer ripped
yes it can...check the yellowpages for the part or repair.
Mar 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire front load washer model FTF2140ES2 that will
The rubber around the door tore and the washer leaks bad.where do i find that part.
Jan 20, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire FTF2140FS Front Load Washer / Dryer Logo
324 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
