Question about LG Washing Machines
Need a part for my top loader - filter attachment WF 561 SPP The material has torn off....
ginko
  • 19396 Answers
SOURCE: Outside of drum has four
You find replacements here, just inser your model number
Posted on Aug 29, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
  • 3230 Answers
SOURCE: I am getting error DE
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Posted on Dec 03, 2010
  • 11 Answers
SOURCE: I have a LG Fuzzy logic for a year and a half now,
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Posted on Jan 17, 2011
Water dripping out of a tubular part of outer plastic bowl.This is at the right rear, when viewed from the rear. It is an LG WF-T657 top loader
the plastic tube for the water level control is in that area
check for it to be attached , cracked or loose
Oct 26, 2016 | LG Washing Machines
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
Where can you find the presure switch lg wf- t1233TP
where can I find a display board for my lg wf-t1233tp top loader washing machine
Jul 04, 2012 | LG WFT1071TP Top Load Washer
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have a LG Fuzzy logic for a year and a half now, model WF-8071TTP top loader. it seems that after washing all my clothes are full of fluff. I have cleaned out the filter bag, and all little filters at...
Jan 17, 2011 | LG WFT1071TP Top Load Washer
My 561 refridgerator door gasket is torn and needs replacing. How do I remove the old one?
I sure look carefully for solutions - some clown just replaced mine for a mear - get this $750 dollars. I assume I've been ripped off, my bride handled the call - don't use REO appliance -
Jul 14, 2009 | Sub-Zero 561 / F
NEED ORIGINAL DOORS ON MY 561 SUB ZERO LOOKS LIKE DOORS ON FRONT
Given the model serial number I could get your decorative panels. The door itself is a framed door and designed to take a 1/4" insert. You can have new panels made if you have changed the cabinets, order stainless steel panels or put another material of your choosing. If you would like the more about the panels reply with mod and ser number which is in the freezer door jamb at eye level. Open the door past 90 degrees and look in.
Jan 19, 2009 | Sub-Zero 561 / F
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
