Question about Little Giant Pump Submersible
What kind of oil goes in this pump ? Shur-Dri Model SDU25 1/3 HP.
Can I pump gas gas with gas with a shur dri pump?
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
Mar 18, 2018 | Cars & Trucks
I have a Shur-Dri 1 HP above ground pump, Model No. SD-100-01. The propeller is cracked and needs to be replaced. I cannot find anyone who sells just the propeller. They say I have to get a new pump. ...
There is a possibility that this model is not supported any longer. What you are needing is an IMPELLOR. The company that makes sure dry has a lot of information here: http://www.pumpproducts.com/myers-m-39.html
Jan 23, 2015 | Pool & Spa
My shur-dri model sd-100-01 well pump will run for a while and then shut off but will restart after an hour or so. What's wrong?
It is a heat sink in the motor. Most all electric motors come with it. Once it cools down, they work again. The heat sink keeps them from burning up.
Oct 26, 2014 | Cars & Trucks
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
I installed a shur-dri 4"
Hello
If this is a 220 volt pump then it needs to have 2 hot wires,so it would be connected to 2 15 amp breakers.The ground shold run from the pump back to the fuse panel box ground bar.
If this is a 115 volt pump it should be connected to one hot, one nutral, and one ground.
Possible a hot wire is making contact with water and tripping breaker.Or the pump motor is going to ground which means its no good.
Aug 01, 2011 | Heating & Cooling
I have a Shur-dri SD-106 pump. I am looking for a source to purchase replacement impellers. Please advise
call 888-987-8677 this a division of pentair they make shur-dri pumps
Sep 15, 2010 | Plumbing
Shur-dri motor will not run on inverter
If your application is really One Horsepower. 745.7 watts then the inverter should be sufficient. However I can not be sure without more details
Jun 06, 2010 | Electronics - Others
Need head pressure on 1hp shallow well pump SDTS10
reducing the pipe size helps build head pressure.
Mar 18, 2010 | Plumbing
My Shur-Dri Backup Sump Pump does not activate with a power outage.
I presume your pump is having a separate power supply.
It is to operate if and when there is power outage. Am
I right? Check your Shur-Dri backup pump. Plug it to
another power source, and switch it on. If it runs, then
the problem could be power supply. Have this checked
using voltage tester (multitester set at 300 volts) or you
may use an electric bulb.
Dec 03, 2009 | Plumbing
Where can I find a replacement impeller for a Shur-Dri SD-106 pump?
Connect to the internet and type;
http//www.merchantcircle.com/business/Shur.Dri 419-289 1144.
This is where you can find your ShurDri Pump parts.
Oct 25, 2009 | Plumbing
Little Giant Pump Submersible Logo
221 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
