Question about Nikon D70 Digital Camera with 18-50mm Lens
Flash will not stay down
Suddenly my flash popped up and there is no way - short of scotch tape - to keep it down
  • bethas May 29, 2008
    Unfortunately that is not the problem. Have treid many cards and multiple batteries to no avail. Any more ideas - leaving for a big tip tomorrow and will have to take duck tape :)
    Genius:
  • 3,587 Answers
Wow..that's not too cool..especially on a bright sunny day, huh?
ok..can you remove the sim card, and the batteries, then install batteries, after waiting around 4 min..and see if it happens again(taking out the sim card to protect your imagery)..
I suspect you have an unhappy camera memory.
Posted on May 28, 2008
Needle will not stay down on my Sony turntable
I've seen this before when I was a kid, my friend would use a piece of scotch tape and carefully tape a penny, nickel, etc. to top of needle holder to keep it tracking.
Nov 22, 2017 | Sony Audio Players & Recorders
The pop-up flash will not stay down. The release catch appears to be stuck on open
Either tape it down or live with it. The cost of repairs are worth more than the camera and the spare parts are not cheap.
Mar 05, 2011 | Canon EOS Rebel XS 35mm SLR Camera
How to lock the pop-up flash back down after using on Nikon 5700
In Auto mode it keeps come automatically when the power is on. .If you select other modes (i.e; P,A,M ) it does not but you need to pop it up manually. it stays as locked unless you do it manually.
If this does not help and If you need more info pls provide more details for additional solution..
May 04, 2010 | Nikon Coolpix 5700 Digital Camera
Canon EOS Rebel XSi pop up flash won't "pop down"
Do not Tape it down, If the flash is pooping up all the time take it to a good Camera repair shop to have the catch replaced. At the same Time you may consider getting a full service done.
Dec 26, 2009 | Canon EOS Rebel XSi Digital Camera
430EX won't fire.
Can you short the pins to have the flash fired?a.l9609@gmail.com
May 27, 2009 | Canon Speedlite 430EX TTL Flash
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Nikon D100 SLR Built in Flash Repair
allisonsylvi,
That's hard to answer until it is seen by the repair person, a reputable repair shop might be able to cannibalize another camera for the pop up flash parts pretty cheap and you just have to pay his hourly rate (the big variable). If the camera still functions otherwise and even the pop-up flash still works, you may want to go low-tech and hold it down with black electricians tape. You can turn off the flash so it won't want to pop up even in low light situations. If you use a flash attachment it will produce better results anyway. The D100 is a tough camera, lots of photojournalists were the first to embrace it for its durability out in the field. (metal body as opposed to plastic parts)
randy320sgi
Jan 07, 2009 | Nikon D100 Digital Camera
Error 5 ! Canon Rebel Xti w/ 28-135mm It was working fine! had it for 10 day's and after about 560 images taken ( 4 gig flash card ) The message read : "The built in flash auto pop up was...
  • Try the scotch tape or masking tape technique: get around two to three inches long sticky tape, stick about an inch above the flash housing, turn on the camera, hold the remaining tape upward , shoot the camera and pull the tape upward with a force enough to pull-up the flash bulb housing.
Jan 04, 2008 | Cameras
Taking photo's requiring the flash.
the flash housing unit is stucked!!  Try to do this: use around 3 inches sticky tapes like scotch tape or masking tape, stick the 1/3 part on the flash housing unit , now set the release button while pulling the tape upward, do not apply too much force, you are trying to help the housing to go upward not to detached it, ha ha..( the sticky tape is safe to use, dont worry). It always work but in case it does not work from your unit try this dangerous one, using small metal and pressing the release button try to open the door ( yes, like opening the stucked door!), its dangerous that yo might detached the housing from the unit, so be carefull. [:0)
Oct 12, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
94 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
