Question about Intermatic Programmable 24 Wall Switch Timer Ej351c
I have the EJ351 model and when it is programmed the lights come on at the desired time; but it never turns the lights off. Manually it works fine and turns the lights on and off.
Http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
See the manual
I think you forgot to set the OFF time that corresponds with the ON time, or your on-off times conflict with each other
Make a chart of you on off times
Clear programming
After setting present time,
Rotate dial clockwise to first ON time, push button in to set ON time
Rotate dial counterclockwise to first OFF time, push button to set OFF time
Repeat this up to 8 times >>> but don't overlap your ON-OFFs
Posted on Oct 07, 2010
EJ351 is programmed to work. In the on position the light it controls is on properly. in the automatic off position the light is on at approximately half intensity. When the manual control is in the o
This timer is rated for incandescent light bulb only.
With 40 watt minimum.
With 100' maximum distance between bulb and timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej351
EJ351 is not rated for CFL bulbs (or motors etc).
CFL bulbs are considered inductive loads (same as motors), while incandescent bulb is resistive load (same as a heating element).
Both types of loads use electricity differently.
Programmable wall timers are not ordinary on-off switch... unless you use the override switch.
... instead timers control electricity with electronic circuit board.
So when the manufacturer designs the electronics inside the timer, the design must anticipate how the electricity is used by the load.
Older designs like EJ351, and some modern timers, are not rated for CFL.
... however most newer timer designs are rated for both resistive and inductive loads.
Always read the specification sheet for load rating before installing programmable timer.
Nov 01, 2014 | Intermatic Programmable 24 Wall Switch...
My EJ351 programmable timer has work perfectly since 2004. A few days ago the red light just started to continuously flash. I turn it off to rest and regrogram but no luck, the indicator light still...
What is amazing is that you know the year of purchase, AND remember how to set the timer.
1) Try turning off circuit breaker and see if timer resets.
2) Buy cheap circuit analyzer and plug into outlet on same breaker and see if line is clean.
3) EJ351 has limited 1 year warranty.
I test timers: usually when in-wall timer goes bad, it needs to be replaced.
There are no repair parts.
Google search: Intermatic EJ351 timer
Amazon sells EJ351
http://www.amazon.com/dp/B000Q9YUGU/ref=asc_df_B000Q9YUGU1408425?smid=ATVPDKIKX0DER&tag=nextagus0039178-20&linkCode=asn&creative=395093&creativeASIN=B000Q9YUGU
Aplus supply sells Ej351 timer.
http://www.aplussupply.com/intermatic/timer.htm
I buy timers from both these suppliers.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Intermatic Programmable 24 Wall Switch...
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Rotate the time dial clockwise at least one click, stopping at
the half hour nearest to the present time.
NOTE: During programming, be careful not to press the
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
Press the dial once to set the present time. The Red indicator
light will go off.
Rotate the time dial clockwise to the first desired ON time.
The Red light will pulse momentarily with each click.
Press the dial once to enter the ON time. The light controlled
by the switch timer will turn ON.
Rotate the time dial clockwise to the desired OFF time.
Press the dial once to enter the OFF time. The light controlled
by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting.
Continue to rotate the time dial until the Red indicator light
comes ON and stays ON, indicating that the switch timer is in
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
I have a intermatic ej351 in my garage to turn the outside coach lights on and off. I made the mistake of putting some 10 year bulbs in the coach lights and now the red light on the timer just flashes...
I answer questions for free.
I specialize in timers and electrical devices
Below is the manual for the EJ351
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The red light is a good indicator of the EJ351 timer.
The manuals says that you can clear all programming by moving control lever to OFF-CLEAR position for 20 seconds.
After programs are cleared, the red light will turn off.
Then move control lever to ON position, and then red indicator light will start flashing.
So the problem may be that the timer programs were accidentally cleared.
Use the instruction manual to re-program your timer.
Add a comment if you need more assistance, and I will help.
Nov 02, 2010 | Intermatic Timer E1020, Single pole/single...
I have the Sentry - timer for my outside lights. One dial is for pm and one for am. The lights are not going on when I put the dial on 7:30 pm. I have to manually turn them on and then off in the morning,
Ginger,
It sounds like an older Intermatic timer
Does your timer look similar to this timer? EJ351
Here are the instructions for this timer:
Usually if the timer is still made, I can find a manual and piece together a solution... but I don't know this timer, and if it is malfunctioning ....
It may be time for a new timer > the EJ351 is inexpensive, simple to install (just 2 wires) and simple to program >>> one knob controls both AM-PM.
Oct 04, 2010 | Intermatic Programmable 24 Wall Switch...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
Sep 19, 2010 | Hardware & Accessories
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
Manual override no longer turns lights on/off
This sounds wrong. Normally Red would go to Live, Black to Neutral and White would go to the light but without more details of the model it's a guess
Dec 06, 2009 | Kitchen Appliances - Others
Intermatic Programmable 24 Wall Switch Timer Ej351c Logo
156 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
