Question about HP Color LaserJet 2600n Printer
Signals taht certridge door is open after cleaning it's scanner
One of my printer cattridge is bad particularly the yellow cattrigde , its pour ink on my printer ,can i print without it and more also my printer is displaying open door can that be the course of the prolem? pls help
Posted on May 04, 2011
How do you clean the scan units?
Posted on Oct 07, 2010
The paper partially feeds in the upper tray and then you hear a grinding noise and it says scanner failure
clean the rollers
Used a clean paper
Open the area the paper feeds in on the scanner
lift the roller
without paper try to make a copy
press the flag-like hardware part on the ground portion of the scanner feeder
then forcefully put the whiteroller to the ground as if its trying to make a copy without the paper
to test if its working fine while you are pressing down the flag structure on the ground area also do it 2x
- wipe the rollers
- specially the one that feeds up the paper
try to scan again
- in case no go
= remove all removable parts
paper, cartridges ,black box and power supply
lift the printer turn it upside down makse sure the cover is open
so taht any foreign material will fall
shake it for 5x
return all the parts
- in case no go
have a printer repair on your area
usually its only on the rollers
- Hope it help
May 28, 2011 | Computers & Internet
Panasonic Hi-speed scanner
I am not sure if you have the manual for it so here it is just in case.
http://service.us.panasonic.com/OPERMANPDF/KVS2026C.PDF
Since there are many steps to opening it to clean, the problem may be reassembling it. You can also unplug it and leave it off for 30 minutes to reset its internal memory. You can also press Start and hold it for 5 sec and do the same with the menu button. If after trying this, your machine does not reset, let me know.
Nov 18, 2007 | Panasonic KV-S2026C Pass-Through Scanner
Microwave stopped working??
Your microwave safety interlock mechanism is faulty. They are hooked right into the main power . Its very complex...the schemnatic looks like a safety system for a nuclear warhead or something -- it's overkill.
But microwaves are involved. Sometimes you can clean them but my experience is taht once they go they're gone because the door latches are just plastic and they do wear down and simply won't have enough material on them to get all the switches to work.
Jul 14, 2010 | Kenmore 63792 Microwave Oven
After self-cleaning cycle, display is blank and door is still locked. Oven is cool.
Here is a tip taht I wrote about self cleaning ovens... it also includes some things to try when this happens...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 04, 2010 | Whirlpool GBD307PD Electric Double Oven
When I switch on the scanner it dispalys a E2 Message
Open the front door and look for a small switch actuator that has been knocked out of position
Aug 26, 2009 | Fujitsu ScanPartner fi-5120C Pass-Through...
Oven door is open, but F9 now signals, trying to turn on
HI. this F-9 code is signaling a major door mechanism malfunction. the best action is to replace the entire door latch assembly. this will heel the F-9 alert and, fix the problem you are experiencing at this time.
Please rate and, have a great evening:)
Jun 16, 2009 | Amana AOCS3040 Electric Single Oven
Error Code 5 on Canon MP160 Printer
your problem is waste ink absorber is full,you need the canon mp tool which is use to reset the counter of your printer,but you must dismantle your printer to clean the waste absorber because if you will reset the counter without cleaning it, all waste ink will overflow on your printer.
Apr 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have opened the above door and have cleaned the mirrors front
check the cables connected to scanner pcb monted left side of the machine. there is a flat cable connected to the pcb from scanner unit. layer of contacts may not be correct. check, clean and re-inatall the cable.
Dec 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Door open
There are quite a number of sensors in any scanner. Sometimes shreds of paper get stuck inside the scanner and create a false alarm like this. Blow with a vacuum cleaner and try. wipe clean the sensors. Dont use solvents.
S. Mohan, Chennai. India.
Nov 13, 2008 | Canon DR-2580C Path-Through Scanner
HP Color LaserJet 2600n Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
