Question about Compaq Computers & Internet
Lcd monitor my laptop lcd monitor has a 2inches fade white color vertically in the center but i still see whatever images in the screen but still you can see the white color in the monitor specially if its in the dark images. please help me with this. thanks!
    Problem Solver:
  • 5 Answers
Maybe someone pushed on the screen if so it is not fixable, probably not anyway take it back to store and tell them it was like that when you bought it
Posted on May 29, 2008
Viewsonic va2431wm monitor, lCDd slowly fade from normal screen to white. The monitor turns on but only get white screen, no color. Open monitor, nor bad capacitors. Why no picture?
Hello, unfortunately this is usually due to hardware problem, In this specific situation it is most likely the problem with lcd panel itself (electronic on panel). Sometimes it can work after the units becomes cold (not working for some time) and you power it on again.
Anyway if you are not familiar with electronics , please visit proper service center, due to the high voltage inside.
Hope this helps.
Oct 21, 2014 | ViewSonic Va2431wm LCD Monitor
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
My Acer Laptop screen fades or goes out when moved
Try reseating the video cable/connector. Also connect an external monitor to the external video port, power up the monitor first then boot up the laptop. The video image should automatically divert to the monitor, if you see a normal video image then the video card is OK and the problem most likely the LCD screen.
Jun 07, 2009 | Ace Computers Computers & Internet
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
White screen
Use an external monitor all should be ok the LCD screen is faulty you can enquire about it here:
http://lcdrepair.net
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
85 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
