Question about Miller Welding Tools
I have Bluefire 180 with a Honda engine. When you strike an arc the motor lugs hard, like its on full power but the arc is weak and the motor almost stalls. The 120V output is fine. The amp adjustment pot changes in resistance when moved. The motor is not the problem. I cleaned the slip rings and the brushes are good. No obvious loose connections.
  • 313 Answers
SOURCE: miter saw motor slowing down
motor comm might be a problem.see if tha armature comm are fine.if their is gap with comm bar & discolorization with mains needs aramture etc.
Posted on Jun 01, 2008
ginko
  • 19396 Answers
SOURCE: 1993 cavalier engine stalls.
Start checking and eventually replacing air filter, spark plugs, and fuel filter, check that air intake is not obstructed.
Posted on Oct 12, 2008
  • 10 Answers
SOURCE: Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Posted on Oct 29, 2008
  • 11 Answers
SOURCE: no weld output or 115v output
Hi
My name is rob, lets see if we can solve your problem
If the welders been working ok first question is what has changed, has it been moved or modified in any way?
Next, are ther any fuses or breakers fitted? are these ok?
Next, most engine driven welders have one major problem.
Vibration.
It shakes stuff loose, undos connections and damages static components,
Take some covers of to expose the internals and with THE ENGINE STOPPED check along the length of the cable harness especially at the ends of cables, give each terminal a tug with the cable to make sure there are no problems there. Also check the condition of the insulation of the harness along its lenght. at this point you may find a "hidden" in-line fuse somewhere in the harness if your lucky!
If none of this helps it gets a little more tricky, could you give me make and model? that would help a lot.
Regards
Rob
Posted on Feb 08, 2009
mamicheddy
  • 79 Answers
SOURCE: Generac portable generator doesn't produce power
Remove front cover on the genset and you will see the brushes and rings. Clean the rings if black with emory cloth and inspect brushes. Flash the fields by apply a 12V battery to the brushes. the brush closest to you or the bearing is connected to the positive side of battery and the back brush is negative. You have to do this with genset running. You should notice your voltage climb up to over 50Vac maybe even over 100Vac. Make sure to use rubber gloves when flashing fields and keep hands away from rotating parts. if voltage does increase when flashing the the voltage regulator is shot. If voltage does not climb then you will need a new genset or generator end.
Posted on May 15, 2009
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
Dec 08, 2015 | Welding Tools
Slow throttle reponse to load
Your welder is too much for the generator you are using. Usually you need a fairly big generator for welding so it doesn't overload so easily.
Nov 18, 2013 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
My Honda CRV 2002 holds down and do not advance,What shoudl that be? and what should I do?
explain.
but sounds motor weak or tranny slippage
post full symptoms, hot and cold engine. and all modes.
speed, hills , all modes what it does good and bad.
Sep 29, 2013 | Honda CR-V Cars & Trucks
I have a lincoln power arc 4000 it sat for several years in my shop i tried to use it, the motor runs but it has no power output on the generator side or the welder side. I let it run for about 10 minutes...
Not sure what the problem is but I have similar unit and the engine died. If you are interested in selling the unit/engine please email me at m_ramkiss@hotmail.con. My mobile is 1-868-366-9505.
Thanks Mike
Feb 26, 2011 | Lincoln Electric POWER ARC 5500 HONDA
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
My Hobart 175 Handler wire feed stops shortly after the arc is struck. Recovers in about 20 seconds. Motor protection ckt is probably doing it. No restriction in feed cable or gun, wire moves smoothly....
Yes sounds like it is "Detecting" a "Fault" condition and shutting down the Arc for safety, then it recovers, and it repeats, I think, you should Check, your Earth leads, Connections, and Overcurrent Protection Threshold if there is a control. Check power is going to the feed motor at time of arc, and if it is still getting enough or if it, the voltage to it,"Sags" under load...In this case it is a power supply problem.
Mar 10, 2010 | Welding Tools
Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
Nov 15, 2009 | Welding Tools
I have a speedline 180 amp arc welder and it doesn't want to arc i turn welder on it makes the nose its spose to make and i connect my earth go to strike and nothing happens? any ideas??
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Sep 08, 2009 | ARC Welding Tools
I have a airco super hornet welding generator/power plantthat will not strike arc it is engine driven
Adequate ground?
Power output at receptacles?. Connections are yusually the problem Engine speed 1800 rpms (high idle) good luck
Jul 26, 2009 | Welding Tools
Welding Tools Logo
196 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
